How to Make Easy Ice Bowls
946
5
12
Introduction: How to Make Easy Ice Bowls
About: I started Craft Invaders for the simple reason that I wanted my kids to see me make things, and to have a go at making things themselves. I love thinking up quirky craft ideas using everyday items that are fou…
Ice bowls make a fun and elegant centrepiece for a party and making them couldn’t be more straightforward with our super easy method. We decorated ours with pretty edible flowers but you can easily customise them to suit your theme and the time of year.
Step 1: ​What You Need to Make an Ice Bowl
I packet of Blu Tack
2 nesting stainless steel bowls - one slightly smaller than the other.
Hint: I advise using metal bowls for making ice bowls as both ceramic and glass. When water freezes, it expands and can cause glass and ceramic bowls to crack
Decorations to sit in the ice (I used edible flowers)
Previously boiled water.
Hint: Tap water contains lots of oxygen bubbles which give a cloudy effect when frozen. For a more transparent result, use water that has been boiled and allowed to cool.
Small can or similar to act as a weight.
Step 2: How to Make a Pretty Ice Bowl Decorated With Edible Flowers
To begin, cut the Blu Tack into quarters, and roll each one up as shown in the photo.
Step 3:
Lay the flowers face out around the inside of the larger of the two bowls.
Position the 4 rolls of Blu Tack equally spaced around the rim of the bowl.
Step 4:
And centre the smaller bowl on top, pushing it down on to the Blu Tack.
Use a jug to pour water between the two bowls. Depending on the size of the gap, you may find that some of the flowers float up. If they do, you can use a chopstick or similar to push them back under the water line.
Place the small can in the centre of the top bowl. As the ice bowl freezes, it will expand, and the weight stops the top bowl popping off the Blu Tack under the force of the ice.
Pop in the freezer and freeze for a minimum of 8 hours.
Step 5: How to Remove Ice Bowls From Their Mold
Do not be tempted to run the metal bowl under the tap. A quick release using even lukewarm water can cause fractures in ice bowls.
Take out of the freezer and leave to stand for 15 minutes. You should then be able to remove the top bowl easily.
Place a plate over the outside bowl and turn over, your ice bowl will slide out on to the plate.
Step 6:
To return it to the freezer for storage, wrap it in plastic wrap or foil for protection.
How long an ice bowl lasts is dependent on a few factors. How thick the ice is. The ambient temperature and what you serve in it.
I suggest you use it on a plate or tray to catch any water as it melts. A doily or napkin is also helpful to prevent the bowl from sliding about.
Step 7:
Ice bowls look gorgeous filled with delicious sorbet on a summer day but are equally fun in winter with the added bonus that they last much longer.
Why not use them to serve a batch of snow ice-cream for a unique, winter dessert.
Visit our blog Craft Invaders for more easy to follow craft tutorials. We love to think up quirky, out-of-the-box craft ideas so you don’t have to!
Frozen Treats Challenge
Be the First to Share
    • Pumpkin Challenge
      Pumpkin Challenge
    • Build a Tool Contest
    • Mason Jar Speed Challenge
    12 Discussions
    Italiankiwiblog
    Italiankiwiblog
    1 year ago
    These bowls look beautiful, and the added advantage is that there's no washing up afterwards!
    CraftInvaders
    CraftInvaders
    Reply 1 year ago
    I'm all for reducing chores! Thanks for your kind comment :)
    CraftInvaders
    CraftInvaders
    Reply 1 year ago
    Thank you :)
    AmyandTanner
    AmyandTanner
    1 year ago
    beauitful just on it's own!
    CraftInvaders
    CraftInvaders
    Reply 1 year ago
    Thanks Amy - I do love how the flowers look in the ice :)
    AnandM54
    AnandM54
    1 year ago
    Wow ..... Great idea and way of done it ...!!
    CraftInvaders
    CraftInvaders
    Reply 1 year ago
    Thanks so much :)
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    That's lovely and that tack seems really handy :)
    CraftInvaders
    CraftInvaders
    Reply 1 year ago
    Thanks Penolopy - The Blu Tack really does make the bowls so easy to make :)
    jessyratfink
    jessyratfink
    1 year ago
    Those violets look so vibrant in the ice! Really gorgeous :)
    CraftInvaders
    CraftInvaders
    Reply 1 year ago
    Thank you so much Jessy :)
