How to Make Guacamole
Ingredients:
1 Large Avocado
1/2 House Tomato | Chopped
1/4 White Onion | Chopped
(Optional) 1/2 Jalapeno | Chopped
Juice of 1 Lime
Cilantro | 2 Tablespoons Chopped
Garlic | 1 Clove Minced
Sea Salt | To Taste
Step 1: Wash All Produce
Wash all the produce that is being used by thoroughly running and gently rubbing produce under cold water.
Dry off any excess water on produce with a clean kitchen towel or paper towel.
*Produce: Large Avocado, House Tomato, White Onion, Jalapeno, Lime, Cilantro, Garlic
Step 2: Cut Large Avocado
Using a sharp straight-edged knife, slice through the avocado lengthwise until you feel the knife hit the pit. Then fully rotate the avocado, keeping the knife steady, to make a cut all around the pit.
Using your hands, twist the two halves apart.
*Safety Tip: Do this on a cutting board.
Step 3: Remove Avocado Pit
Using enough force, aim the knife at the pit of the avocado and whack into it.
Then twist the knife and pull out the pit.
*Safety Option: Remove the pit using a spoon, by inserting the utensil underneath the pit and lifting.
Step 4: Mash Avocado
Use a spoon to loosen the skin all the way around, and scoop out the avocado.
Add the avocado to bowl/container and mash the avocado with a fork until it is fully mashed.
Step 5: Chop House Tomato
Using a sharp straight-edged knife, slice straight through the tomato lengthwise until the tomato is cut in half.
Using a spoon, remove the tomato seeds by inserting the spoon and scooping out the seeds.
Arrange the tomatoes next to each other, or stacked on top of each other. Slice them into strips. Now slice the tomato into a same-size dice.
*Tip: To have very small dice of tomato, make the slices close together.
Add the chopped house tomato to bowl/container.
Step 6: Chop White Onion
Using a sharp straight-edged knife, slice straight through the white onion lengthwise until the white onion is cut in half.
Using a sharp straight-edged knife, slice straight through the white onion lengthwise, again until the half white onion is cut into a fourth.
*Safety Tip: Do this on a cutting board. Using your hands peel the top papery skin layers of the white onion.
*Tip: To have very small dice of white onion, make the slices close together.
Arrange the white onion next to each other, or stacked on top of each other. Slice it into strips. Now slice the white onion into a same-size dice.
Add chopped white onion to bowl/container.
*Taste Option: Add less or more white onion if needed.
Step 7: Chop Cilantro
Using a sharp straight-edged knife, slice 2 tablespoons worth of cilantro.
Arrange the cilantro next to each other, or stacked on top of each other. Slice it into strips. Now slice the cilantro into a same-size dice.
*Tip: If you want a very small dice of cilantro, make the slices close together.
Add chopped cilantro to bowl/container.
Step 8: Mince Garlic
Using a sharp straight-edged knife, chop off root end of the garlic, then crush garlic between the side of the knife and cutting board to loosen papery skin.
*Safety Tip: Do this on a cutting board. Using your hands peel the top papery skin layers of a clove of garlic.
*Tip: To mince garlic, make the slices close together.
Arrange the garlic next to each other, or stacked on top of each other. Slice it into strips. Now slice the garlic into a same-size dice.
Add minced garlic to bowl/container.
Step 9: (Optional) Chop Jalapeno
*Safety Tip: When handling jalapeno, do not touch eyes or face, and wash hands afterwards.
Using a sharp straight-edged knife, slice straight through the jalapeno lengthwise until the jalapeno is cut in half.
Use your spoon to loosen the jalapeno seed all the way around, and scoop out the seeds whole.
Arrange the jalapeno next to each other, or stacked on top of each other. Slice them into strips. Now slice the tomato into a same-size dice.
*Tip: To very small dice of jalapeno, make the slices close together.
Add chopped jalapeno to bowl/container.
*Taste Option: Add less or more jalapeno if needed.
Step 10: Mix Produce Together
Using a utensil, mix guacamole.
Step 11: Add Salt
Add salt to bowl/container until liking.
*Taste Tip: Once guacamole is mixed add more salt if needed
Step 12: Add Lime
*Tip: If guacamole won’t be eaten right away, then do this step until guacamole will be eaten.
Using a sharp straight-edged knife, slice straight through the lime lengthwise until the lime is cut in half.
Add lime to bowl by squeezing the lime until liking.
*Taste Tip: Once guacamole is mixed add more lime if needed
Step 13: (Optional) Preservation
If preservation of the guacamole is needed, add the pit of the avocado into the guacamole
    • Backyard Contest
      Backyard Contest
    • Growing Beyond Earth Maker Contest
    • Sensors Contest
      Sensors Contest
