How to Make Macarons for Beginners
This is a recipe and step-by-step-guide for how to make macarons. If you are a beginner baker and have never made macarons before, use this recipe to get the perfect macarons! The recipe for the macarons is from BuzzFeed Tasty. Link to original recipe: https://tasty.co/recipe/macarons
Teacher Notes
Step 1: ​Ingredients for Macarons and Buttercream
Macarons:
- 1 ¾ cups powdered sugar
- 1 cup almond flour, finely ground
- 1 teaspoon salt, divided
- 3 egg whites at room temperature
- ¼ cup granulated sugar
- ½ teaspoon vanilla extract
- 2 drops of gel food coloring
Vanilla Buttercream:
- 1 cup unsalted butter (2 sticks), at room temperature
- 3 cups powdered sugar
- 1 teaspoon vanilla extract
- 3 tablespoons heavy cream
Step 2: Tools Needed
- 3 large bowls
- Egg yolk separator (optional)
- Food processor (optional)
- Sifter
- Handheld mixer
- Spatula
- Piping bag with a rounded tip
- Baking sheet
- Parchment paper
- Wire rack
Step 3: Step 1: Separate Egg Whites From Egg Yolks
The tool above is an easy way to separate the egg whites from the egg yolks. Crack the egg over the tool, so it catches the yolk, letting only the egg whites fall into the bowl. Another method if you don't have this tool is to use the egg shell to separate the yolk from the whites. Once the egg whites are separated from the yolk, let the whites rest for at least 30 minutes or until they are at room temperature.
Step 4: Step 2: Prepare Dry Ingredients
In the bowl of a food processor, pour the almond flour, powdered sugar and salt. When measuring the almond flour and powdered sugar, use the spoon and level method: Use a spoon to pour the flour or powdered sugar in the measuring cup, making sure not to pack, and level the excess off with the back of a knife.
Step 5: Step 3: Pulse Dry Ingredients
Pulse the dry ingredients at least ten times. You want the flour, powdered sugar, and salt to be very fine. (Skip this step if you do not have a food processor and use a flour sifter instead.)
Step 6: Step 4: Sift Dry Ingredients
Pour the dry ingredients into a large bowl through a flour sifter multiple times to get out any extra lumps.
Step 7: Step 5: Beat Egg Whites
Once the egg whites are at room temperature, beat the egg whites and 1/2 tsp of salt with a hand mixer, using a whisk setting. Beat the eggs and salt until they are not transparent, and have a white, foamy texture.
Step 8: Step 6: Add Sugar to Egg Whites
Gradually add the granulated sugar to the egg whites mixture while beating it with the hand mixer. Beat until the mixture forms peaks. If the peaks are falling over, the mixture is undermixed. The peaks should be stiff and not fall over. If the batter is mixed well enough, you can tip the bowl over and none of the mixture will fall out.
Step 9: Step 7: Add Vanilla and Food Coloring
Add the vanilla and gel food coloring into the mixture and beat just until incorporated.
Step 10: Step 8: Add Dry Ingredients to Egg Whites
Add a third of the flour mixture to the liquid mixture. Mix the flour into the liquid mixture with a spatula by folding it slowly. Continue adding thirds of the flour mixture until it is incorporated. You should be able to make a figure eight the the mixture with it breaking.
Step 11: Step 9: Prepare Baking Sheet
Pipe a small portion of the batter into each corner of the baking tray so the parchment paper sticks to the balking tray.
Step 12: Step 10: Pipe the Macarons
Using a piping bag with a rounded tip, pipe 1.5 inch wide, in diameter, circle on the tray at least an inch apart from each other. A piping bag is preferred but if you do not have one, you can use a ziplock bag with the corner cut off. The number of macarons should be even so every cookie has a corresponding cookie to make the macaron.
Step 13: Step 11: Drop the Baking Tray
Lift the tray a few inches from the counter and drop it onto the counter five times to release an air bubbles.
Step 14: Step 12: Let Cookies Rest
Let the cookies set at room temperature for 30 minutes to an hour.
Step 15: Step 13: Bake the Macarons
Bake the cookies for 17 minutes at 300 degrees fahrenheit.
Step 16: Step 14: Beat Butter for Frosting
For the frosting beat two sticks of butter that are at room temperature with a hand mixer. Mix until light and fluffy.
Step 17: Step 15: Add Powdered Sugar to Butter
Gradually mix in sifted powdered sugar and beat with hand mixer.
Step 18: Step 16: Add Vanilla and Heavy Cream to Frosting
Add vanilla and heavy cream to frosting and mix with hand mixer.
Step 19: Step 17: Pipe Frosting Onto Macarons
After the cookies are out of the oven and cooled. With a piping bag and whatever tip you want, pipe the buttercream frosting onto half of the cookies.
Step 20: Step 18: Sandwich the Cookies
Sandwich the macarons together and enjoy!
Be the First to Share
    • Kitchen Skills Challenge
    • Teacher Contest
      Teacher Contest
    • Growing Beyond Earth Maker Contest
