How to Make Power Bank Using 9v Battery | Portable Power Bank | Fast Charging
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hello so here is the tutorial for power bank finally i make it there are lot of people traveling around the world and they need power bank so this power bank is portable and easy to carry when you travel around the world .
Each and every thing is shown also in video step by step and this is really easy diy do it yourself project anyone can make at their home easily
Watch Video For Step By Step Instruction...
Please Subscribe to instructable also on our channel
⟹ https://www.youtube.com/channel/UCi6ZqREHDIx2xLrCRkrRS0w
Step 1: Circuit Diagram
This circuit is very easy there are three pins of lm7805 regulator make connection as shown in circuit diagram or if facing any difficulty watch video
Step 2: Hardware Required
Hardware Required
  • 9V Battery (800-2000mah prefered) with Clip
  • Micro USB Cable
  • LM7805 5V Regulator
  • Card Sheet
    • Organization Contest
    • Warm and Fuzzy Contest
    • Paper Contest
      Paper Contest
    2 Discussions
    Pchristu
    Question 8 months ago on Step 1
    Any reason this could not be applied to a Lightning port for iPhone, or any mods necessary, different regulator?
    1 answer
    pyromaniac303Pchristu
    Answer 7 months ago
    May work with an iPhone, though sometimes you have to do strange things with the data lines to get them to charge, depending on which model you have. Some require the data lines connecting together, some require resistors on the data lines also.
    Might be worth adding a couple of capacitors (a few uF on the input and output for stability) as most regulators specify it in the datasheet, though they usually work without just fine.
