How to Make Quilt From Old T-Shirts
371
6
8
A lot of people wanted in world loves to reuse their clothes like me as I have shifted from a warm place to colder one ! . I need a quilt to keep me warm but when i go in marketplace . They are very Costly and i ended up with blank hands . Now when i am arranging my clothes in cupboard i see a bundle of half t-shirts lying unused. from there I got a idea to make this quilt
Special Note:- You can easily change T-shirt with Sarees , shirts , old clothes or any other Fabric or Old Clothes
Supplies:
  1. 30 shirts -2.2 Meter fleece (you only use about 1.8 Meter, but I would buy extra just in case you mess up)
  2. 7.3 Meter extra wide single fold bias tape
  3. 9.5 Meter apparel interface material (it’s really thin, the thinnest interfacing )
  4. iron and ironing board
  5. thread that matches the fleece
  6. thread that can be used to sew the shirts together like black, grey, or white (it won’t really be seen unless you mess up!)
  7. thread that matches the bias tape
  8. good scissors for cutting (I recommend the brand Kangaroo)
  9. PINS! Tons and tons of pins. Your entire quilt depends on your use of these pins
Step 1: Choosing the Right T-shirt
Pick out 30 t-shirts. I only used 26 I think, because I used both the back and front of a few shirts Because we are Indians and we love saving . But basically, you need 30 different pieces of shirt for the quilt squares.
Lay out the shirts in a 5 x 6 fashion that is appealing to the eye and take a picture of it.
Remember that choose the right color and design so that colors and designs co-ordinate with each other
Step 2: Cutting the T-shirt
Cut out your shirts in the correct sized quilt square you want. Use a piece of cardboard as your guide, and trace the cardboard onto every shirt and cut them out. I actually used two different sized squares (and it become messy) . Remember Use one piece of cardboard in a size that you like, and stick with it!
You Can use a piece of clear fiberglass from Home Depot that we can cut with box cutters to be the size we wanted. It’s much easier to use than the cardboard because the shirt sizes are more consistent and you can see through the glass to make sure You're centering the logo! In addition, during this step, you don’t cut the shirts out exactly. I usually leave a little extra, put the interfacing on (see next step), and then trim them both for a clean edge. This also saves a ton of time!*
Step 3: Interfacing & Trimming
Iron on the interfacing to the back of each shirt.
a.) Lay out a shirt facedown on your ironing board. I did 2 at a time to speed things up, but 1 at a time is fine.
b.) Put the interfacing on top of the t-shirt. Interfacing has 1 smooth side and 1 bumpy side. The bumpy side should be facing down, against the t-shirt. The textured side is actually hundreds of little glue dots that stick to the material once heat is added.
c.) With the iron at the highest setting but without any steam (i.e. don’t add water just turn it on), iron the back of the interfacing to the shirt. Be sure to get the shirt corners really well or else the interfacing will fall off and that’s just annoying. The picture in previous step is what it looked like after I ironed the interfacing on, but before I trimmed out each quilt square
Trim the extra interfacing off each shirt. This step is fun because it’s not frustrating or time-consuming – the shirts are now stiff because of the interfacing and it’s so easy to trim them. Enjoy doing this, because it’s going to get difficult pretty soon! Now you have 30 beautiful fabric squares and it’s time to sew!
Step 4: Sewing Step-1
Sew the horizontal rows of the squares together. Here is where your pins come in handy.
a.) Take your first two squares in the top row and lay them side by side.
b.) Flip the square on the right on top of the square on the left, so that the “right” sides of both shirts are touching each other.
c.) Pin along the right side of the square, going through both layers of fabric. Open up the fabric to double check that each shirt is where it should be (i.e. not upside down and pinned together on the correct side).
d.) Sew along these pins. I used the presser foot of the machine as my guide, so it was about an 1/8″ seam. Make sure to take out each pin before you sew over it or else the needle in the machine will bend or break and that’s not good.
e.) repeat this process, adding onto your two connected squares until you have completed the top row of your quilt.
f.) repeat for each of the six rows
Step 5: Sewing Step-2
Iron the seams in every row open. Use your pins to hold the seams down and make them nice and flat. Be careful not to burn the interfacing off and don’t melt your pin heads. Basically, I used the tip of the iron and carefully flattened each seam. Yes, it’s very tedious, but necessary.
Sew the 6 rows together.
a.) Take the top two rows.
b.) Flip the second row on top of the first row so you’re looking at the back of the second row squares.
c.) Pin along the long bottom edge, doing your best to line up both layers of squares. If you look at my completed picture, I’m sure you can see that mine aren’t perfect but it’s hardly noticeable.
d.) Repeat for the middle 2 rows, and the bottom 2 rows. So now you should have 3 bigger pieces, 2 x 5 each. In the picture above, only the top two rows are connected.
e.) Put together the three large pieces using the same process as before (i.e. flipping the second piece onto the top, pinning and then sewing.)
Congratulations! You now have your quilt squares all sewn together!
Step 6: Finishing Step-1
Iron the rest of the seams open. It’s like Step #5, except do the long horizontal seams. This is what the back of my quilt looked like before I ironed down the horizontal rows.
Now Put fleece flat on ground. Place your quilt on top, making sure both layers are as smooth as possible.
Next Find the middle two vertical columns. Pin down both these two seams. So in mine, it was the left and right sides of the shirt starting with the blue Africa shirt, then going down to the yellow pickle shirt, then the black and red orchestra shirt, and so on. When attaching the fleece, you always want to start in the longest middle part and work your way out so it remains as flat as possible, but since there are an even number of vertical lines, pin the two middle at the same time
Step 7: Finishing Step-2
Sew along these vertical lines. This is where your job gets super frustrating and time-consuming, because you have to adjust the material about every five seconds. You don’t want it to get too heavy or stretched in one direction or else the quilt won’t lay flat on the fleece and it’ll be all distorted. Fleece is stretchy, so be careful! Repeat the pinning and sewing process for each vertical row. There’s 4 total.
Now Pin and sew along the horizontal rows in the same fashion as above. Start with the centermost row and do that first, then work your way to the outside. Now the back of your quilt should have a very nice grid on it! And your quilt for the most part should be connected to the fleece, except for the edges. In this picture you can see the pretty grid! Doing all this also adds nice thickness to the quilt overall.
Step 8: Last Finishing Step
Cut off the excess fleece around the outside so that all the edges are flush. Again, pin everything beforehand so both layers stay nice and flat.
Now Keeping the pins around the entire outside edges, sew a 1/8″ seam around the entire quilt. As you can see from the picture, I did each edge separately, then turned the quilt around and did the next edge. Don’t forget to pull the pins out before you sew over them.
Now it’s time for the last part – the bias tape! Take your bias tape and fold it equally around the outside edges, with half of it on the bottom and half on the top so it covers up all the ragged t-shirt and fleece edges. It’s tricky to make it even the entire way, but just be patient and you can do it!
Sew the bias tape onto the quilt. As much as you can, sew along the inside edge of the bias tape to create a nice rounded edge on all sides of the quilt.
Congratulations!! You finished! Now go show off your creation to your friends and family, and be warm!
Sew Tough Challenge
This is an entry in the
Sew Tough Challenge
    • Sew Tough Challenge
      Sew Tough Challenge
    • Sensors Contest
      Sensors Contest
    • Beauty Tips Contest
      Beauty Tips Contest
    8 Discussions
    seamster
    6 days ago
    Looks good! Nice, straightforward process too. Thank you for sharing how you made this!
    Saksham_guptaseamster
    Reply 4 days ago
    I am thankful to you for sparing some time to comment and appreciating Mr efforts ♥️ Please Vote if you like
    Nap52728
    5 days ago
    Yeah you are amazing . Its very impressive that how you maked blanket(quilt) from old t shirts. I will surely try this
    Pangolin-Tree
    5 days ago
    Cool tutorial, nice to see you used fleece rather than batting. I have a quilt I've been working on for over three years, and I've been debating whether to back it with fleece or go the traditional way. Now that I see this, I think I'll do fleece :D
    Saksham_guptaPangolin-Tree
    Reply 4 days ago
    All the best ! For your quilt & thanks for sparing some time to comment in your busy schedule , Please Vote if you like ♥️
