How to Make RGB LED Fan for Computer
About: Hi friends, welcome to "CreativeYT".this channel is created for you by true ideas and easy to Learn Technology. the channel make only small ideas or projects in creative people. so subscribe chann...
In this tutorial I'm going to show you " How To Make RGB LED Fan for Computer "
This method is very simple and for everyone, even you are a Beginner or school going student who wants to innovate something new or for your educational project. This will be the ideal project for you.
Requirement in This RGB Led Computer Cooling Fan Projects :
Computer Cooling Fan ,Connecting Wire ,Glue Gun with Glue ,USB Cable ,Color Changing Led Light ,220 Ohm Resistance LED Compatible
Teacher Notes
Step 1: First You Need to Multi Color Led
Step 2: Then Soldering the Led 220 Ohm Resistance LED Compatible
Step 3: Using Parallel Connection Positive or Negative Terminal Connect the Led With Wire
Step 4: Using Glue Gun to Connect Together
lets a CPU cooling fan,and using glue gun to connect together the led light and CPU fan terminal..
Step 5: Finally Made a RGB LED Fan for Computer
Finally made a RGB LED Fan for Computer if you have any doubt please see the video where i will show How To Make RGB LED Fan for Computer step by step..
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
