How to Make Remote Tester With C945 Transistor
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make a circuit of Remote tester using C945 transistor and photo-diode.We can use this circuit for checking all remotes.
Let's get started,
Teacher Notes
Step 1: Take All Components As Shown Below
Components requires -
(1.) LED - 3V x1
(2.) Photo-diode x1
(3.) Transistor - C945 x1
(4.) Remote (for checking purpose)
(5.) Battery - 3-3.7V (we can use mobile battery of 3.7V)
Step 2: Circuit Diagram
Connect all components according to the circuit diagram.
Step 3: Connect Transistor
Connect emmiter pin of transistor to -ve pin of the battery as solder in the picture.
Step 4: Connect LED to the Circuit
Next we have to connect LED to the circuit.
Solder -ve pin of LED to collector pin of the transistor and
solder +ve pin of LED to +ve of the battery.
Step 5: Connect Photo-diode
Now we have to connect photo-diode to the circuit.
Solder -ve leg of photo-diode to the base pin of the transistor and
solder +ve leg of the photo-diode to +ve pin of the battery as you can see in the picture.
Step 6: Circuit Is Ready
Now our remote tester circuit is ready.
HOW TO USE -
Press any button of Remote towards photo-diode.When we will press any button of remote towards photo-diode then LED will blink.If LED is not blinking then Remote is not working.
If you want to make more electronic projects like this then follow utsource123 now.
Thank you
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
