How to Make Rivets - From Cans ( = Any Tin)
About: always had a deep connection with junk. drawn to it, magically, from childhood on. spent the nights as a boy roaming the streets and looking for trash to take back home. spent # 2 most of my allowance on the...
improvisation is priceless. here a technique to make rivets from a fishcan - or, for that matter, any kind of can, resp (thin) tin in general. its easy, free, and might turn out ´pivotal´ in an emergency etc. ok, put on your hard-head, here comes another crash-course:
ps, in a future post we deal with making hollow pivots, also from *trash*
Teacher Notes
Step 1: _1
to demonstrate the technique lets just split a piece of wood and rejoin it - with a homemade rivet
Step 2: _2
a), drill a hole through the wood (pieces)
b), take some tin (here the lid of a fishcan)
c), cut a strip
Step 3: _3
a), roll up the strip in a coil (i use a sewing-needle and some pliers)
b), cut off whatever exceeds the diameter of the ´rivet´ needed
Step 4: _4
a), insert the rivet in the holes of the two parts
b), leave on each side some extra (which will be falten to form the heads)
Step 5: _5
a), find some solid surface (and, optionally, use some washers about the size of the rivets, underneath)
b), start flatening the tin and forming a head... by hammering (move the hammer also circularly with some inclination towards the centers - that helps to get some roundish shape, if so sought). when one side is done flip the object over and create the opposite head.
Step 6: _6
take off your hard-head
done
thanks for stopping by.
over & out
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
