How to Make Rose Water ... and Why
5,060
72
21
Introduction: How to Make Rose Water ... and Why
About: Hi, I'm Éva from Hungary. I love baking, cooking, and gardening, not to mention the perfect combination: cooking using fruits and veggies from our garden. I often experiment with new ingredients and try to u...
In this Instuctable I will show you how to make rose water. It's a quick, effortless and inexpensive way of arriving at something that has a number of uses and benefits. What is it made of? Rose and water, it's that simple.
It's been used throughout the centuries by women longing to benefit from its beautifying effects. It is said to be one of the beauty secrets of Cleopatra of Egypt. Among others, it has antioxidant, anti-aging and anti-inflammatory properties. So why not try it yourself?
Step 1: Gather Your Supplies
Roses - amount depends on how much rose water you plan to end up with, I used 6 big, organic roses that produced approximately 150 ml rose water. It is very important to use organic, pesticides -free roses, you don't want to apply chemicals on your face.
Distilled water - so as to provide a longer shelf life for your rose water. As for the quantity, add as much water as needed just to cover the roses in the pot.
Pot
Sieve
Clean bottle or jar for storage
Step 2: Prepping
Gather your supplies, remove the petals of the roses and wash them under running water.
Put them in a pot, pour as much distilled water that would be just enough to cover the petals. (Beware, they keep coming up to the surface!)
Step 3: Simmering
Use a small plate as a weight to keep the petals under the water.
Put it on medium heat, and let it simmer for about 20 minutes until the petals lose their color.
You can see in the photos the petals turning pale, by this time all the color has gone into the water. It has a magnificent scent, too!
Let it cool.
Step 4: Finishing Touches
Discard most of the petals with the help of a sieve, strain the mixture.
Step 5: Ready!
Put your rose water in a glass jar.
Since we have an abundance of roses in the garden from May till the end of October, I usually only make as much rose water as would last for about a week or 10 days. Summer is very hot here, so I usually keep it in the fridge, just in case. For the winter, I freeze the rose water in ice-cube molds and keep them in zip-lock bags in the freezer and use them one by one.
How to use it? With a quick search on the internet, you' ll find dozens of uses.
I use rose water regularly as:
1. Toner
You may spray or simply splash the rose water on your face, or you can use a cotton ball to apply.
2. Facial scrub
Mix 2 tablespoons of polenta with 2 tablespoons of rose water, rub it over your face.
3. Body spray
Put the rose water in a spritzer bottle, it is really refreshing after taking a shower.
4. Refreshing spray
Put the rose water in a small spritzer bottle, keep it in your bag, spray it on your face to freshen up. It"s great in the summer heat.
5. Body scrub
Mix 1 cup sugar, 3 tablespoons of rose water, 1/4 cup coconut oil, apply. Works like magic, leaves you with a soft, scented skin.
Beauty Tips Contest
Second Prize in the
Beauty Tips Contest
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    21 Discussions
    Eight is Great
    Eight is Great
    Question 1 year ago
    Can you also use water filtered through reverse osmosis? Also, can you use this same process to make scented water from other flowers?
    Momos75
    Momos75
    Answer 1 year ago
    I nevet tried using filtered water, but I do not see any reason why not. As for your other question I regularly make syrups from other flowers like lilacs and elderflower. Any flower that can be used to make a syrup could be used for making scented water.
    ArtzyPanda
    ArtzyPanda
    Tip 1 year ago
    I attempted to made the rose water body scrub because I have some gifts I have to give away this weekend. I used pink roses as seen in the picture, I also used 10 roses, that made 9 of the jars seen in the picture below, a giant latch jar of the body scrub for personal use and still have a large mason jar full of rose water. The smell is everywhere!
    Momos75
    Momos75
    Reply 1 year ago
    Looks great! The smell is a pleasant side effect :-)
    Don't forget to store it in the fridge and even there, don't keep it too long. Or freeze part of the rose water.
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    I just can't get over how vibrant this is!
    Momos75
    Momos75
    Reply 1 year ago
    I had a hard time taking the photos with just the petals. :-)
    ArtzyPanda
    ArtzyPanda
    Question 1 year ago
    If you make body scrub how far would you say a dozen roses would get you? As in how many jars would you say you could fill.
    Momos75
    Momos75
    Answer 1 year ago
    Depends on the size of the rose, there are so many types! Check the size difference in the photo. The ones I used were really huge. The pot seen in the photos is of 16-18 cm diameter and it was filled with petals at least 6 cms high. For this quantity I added roughly 300 ml water therefore I ended up with slightly less rose water. Since I don’t use body scrub regularly I only prepare one batch at a time. I never measured it, so it is math time. 3 tablespoon makes 1.25 cups. Just checked conversion table, 3 tablespoons is approximately 42 ml which leads to the conclusion that 7 batches that is almost 9 cups can be made.
    ArtzyPanda
    ArtzyPanda
    Question 1 year ago
    Can you use roses that are dried out so they can be shipped or do they have to be full of moisture so to make the rose water?
    Momos75
    Momos75
    Answer 1 year ago
    I do not see any reason why not, but I never tried as we have plenty of roses in the garden.
    Gadisha
    Gadisha
    Question 1 year ago
    Can you just use any rose or just certain types of roses?
    Momos75
    Momos75
    Answer 1 year ago
    Hello, it’s a tricky question, I think I cannot give you an absolutely clear answer. As far as I know all roses are edible (at least the types around here) therefore they can also be used to make rose water. Nevertheless, I am not a botanist, but a lawyer, so here comes a disclaimer: my knowledge is limited I am not taking any liability in this regard.
    For real, though all edible and organic roses can be used, I usually use the classic red rose that has a strong fragrance (seen in the photos).
    biohazarus
    biohazarus
    Reply 1 year ago
    Not only the rose itself, but if the rose was grown with pesticide or other chemical, they may be transfer in the rose water. So be careful on your "source"
    Cat00x
    Cat00x
    1 year ago
    I wonder if there are also ways to use your "rose tea" in food... as a flavoring? Have you tried tasting it?
    Momos75
    Momos75
    Reply 1 year ago
    I’m planning to. Thinking about flavoring the whipped cream on top of Pavlovas.
    Soundbrigade
    We have been using wild roses, which has a more intense smell/taste to make rose liquer. So I'd say wild roses, definitely.
    Momos75
    Momos75
    Reply 1 year ago
    Absolutely. Any type that has a strong fragrance .. and these deep red ones really do.
    4
    Tooraj
    Tooraj
    1 year ago
    Thank you for the instructable, but technically speaking rose water is made from distilling the steam of rose petal. It should be clear as water. Your process is basically making rose tea.
    Momos75
    Momos75
    Reply 1 year ago
    Thanks for commenting. I am familiar with the distilling method, I tried it, too, it’s a lot more complicated yet I do not see a big difference as to the benefits in everyday use. Regarding the terminus tecnicus, I guess you are right.
    jessyratfink
    jessyratfink
    1 year ago
    I bet that smells heavenly! I love rose water - thanks for sharing how to make it :D
