How to Make Single Transistor 5200 to Inverter
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make an Inverter using single transistor 5200.It's circuit is too simple and it require very less components.
Let's get started,
Teacher Notes
Step 1: Take All Components As Shown Below
Parts required -
(1.) Transformer - 12-0-12 x1
(2.) LED Light - 230V (9W)
(3.) Transistor - 5200 x1
(4.) Power supply - 12V DC
(5.) Resistor - 1K x1
Step 2: Transistor - 5200
B - Base
C - Collector and
E - Emmiter
Step 3: Circuit Diagram
This is the circuit diagram of this inverter.
Connect all components according to this circuit diagram.
Step 4: Connect 1K Resistor to Transistor
Firstly we have to connect 1K resistor to Base pin of the transistor as solder in the picture.
Step 5: Connect LED Light to the Output of Transformer
Connect LED Light to the output wires of the transformer as connected in the circuit/as given in the circuit diagram.
Step 6: Connect Power Supply Wire to the Circuit
Now connect input power supply clip to the circuit.
Connect +ve clip to 0-wire of transformer and -ve clip of input power supply to emmiter pin of the transistor as you can see in the picture.
NOTE : We have to give 12V Input power supply to the circuit.We can also give power supply with 12V battery.
Step 7: Give Power Supply
Turn ON the switch of 12V DC power supply.
Now its output power supply can be upto 230V AC.
Thank you
Step 8: Connect Transformer Input Wires
Next we have to solder 12-wire of transformer to Base pin of transistor with 1K resistor and
solder another 12-wire of transformer to Collector pin of transistor as you can see in the picture.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
