How to Make Smoked Salmon
Introduction : Cold Smoked Salmon
This is the culminating instruction on creating a the cold smoke generator. This is where the food is actually smoked.
I have decided to break the instructions into a number of key parts which might just be useful components on their own.
Part 0 - Smoker
Part 1 - Vent
Part 2 - Door
Step 1: Ingredients
All the ingredients to create smoked salmon.
  • 0.75kg Salmon
  • 2.0l water
  • 250g PDV salt
  • 250g Sugar
  • 50g maple syrup
  • 1 clove of garlic
  • 10g cracked black pepper
  • Oak wood (tree)
Step 2: Equipement
Needed to brine and smoke the salmon
  • Large container (plastic trug)
  • Plate
  • Flat dish or oven pan
  • Cold Smoker
  • Charcoal
  • Firelighter
Step 3: Cure the Salmon
Brine the salmon
  • Mix all the ingredients together in the large container
  • Place the salmon into the brine
  • Place a plate on top of the salmon to hold it under the water
  • Leave in a cool place for 6 hours curing
Dry the salmon
  • Remove the salmon
  • Wash the salmon
    • Previously I have never done this enough and the salmon was too salty
  • Wash the salmon more
    • Taste some and check its edible
  • Place in a flat container
  • Leave to dry for 6 hours (The surface will dry and become slightly tacky)
Step 4: Smoke the Salmon
Now just smoke the salmon
  • Cut up the wood into reasonable sized chunks
  • Open all the vents in the cold smoker
  • Add a firelighter to the cold smoker
  • Add a small amount of charcoal
  • Set fire the firelighter
  • Add the wood to the smoker
  • Place the salmon in the smoking chamber
  • Turn on the pump
  • Wait for 6 hours
**There was a certain amount of adjustment needed opening and closing the top vent to keep the smoker working**
**The volume of smoke generated was generally about the same as the video**
**I did a temperature check to make sure that it was same as the outside temperature**
    • Cardboard Challenge
      Cardboard Challenge
    • Epilog X Contest
      Epilog X Contest
    • Toys Contest
      Toys Contest
