Beginner How to Make Spiral Headpins
About: I love books, crafting and DIY. Visit my jewelry shop at https://www.etsy.com/shop/AquamarineGoods. Visit my YouTube channel at https://www.youtube.com/channel/UCvR2KFW_kAQjYpHtkbWZdIQ
This instructable shows you how to make spiral headpins.
Supplies:
- 20 gauge wire
- chain nose pliers
- round nose pliers
- wire cutters
Teacher Notes
Step 1: Loose Spiral Headpins
Cut out a three-inch piece of 20 gauge wire.
Step 2: Bend
Bend the wire at the 1-inch point.
Step 3: Loop
Make a loop at the bend perpendicular to the shaft by putting your round nose pliers in bending the wire around that.
Step 4: Spiral
Keep spiraling until your have a loose spiral.
Step 5: Hammer and File
Hammer the end and file all sharp bits so that they don't scrape anyone.
Step 6: Tight Spiral Headpins
Cut a three-inch length of wire.
Step 7: Bend
Bend the wire at the one-inch point.
Step 8: Loop
Make a small loop similar to before at the bend, perpendicular to the shaft of the pin.
Step 9: Squish
Squish the loop down so it's as tight as possible.
Step 10: Spiral
Keep spiraling around so you get a tight spiral.
Step 11: File
File down any sharp bits so that they won't stick out.
Step 12: Triangular Spiral Headpins
Cut a three-inch length of wire. File the ends (if you file them first, it's a lot easier than filing them after they've been wrapped.)
Step 13: Bend
Step 14: Loop
Make a loop at the bend.
Step 15: Bend
Bend the wire straight up at the bottom of the spiral.
Step 16: Bend
Bend the wire horizontally at the top of the spiral.
Step 17: Finished!
You're done! Here are the finished headpins.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Multi-Discipline Contest
