How to Make Touch ON and OFF Circuit
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make Touch ON and OFF circuit using LM555 IC.When we will touch on wires of one side then LED will glow and when we will touch on the wires of another side then LED will be turn OFF and vice versa.
Let's get started,
Teacher Notes
Step 1: Take All Components As Shown Below
Components required -
(1.) LED - 3V x1
(2.) Resistor - 220 ohm
(3.) IC - LM555
(4.) Connecting wires
(5.) Battery - 6V
Step 2: Conect Pins of the IC
Solder Pin-4 and Pin-8 of this IC.
Step 3: Connect LED
Next we have to solder +ve pin of LED to Pin-3 of the IC.
Step 4: Solder 220 Ohm Resistor
Solder 220 ohm resistor between -ve pin of LED to Pin-1 of the IC.
Step 5: Solder Two Wires for ON
Next solder wires in Pin-1 and Pin-2 of the IC as you can see in the picture.
Step 6: Solder Two More Wires for OFF
Next we have to solder two more wires in pin-6 and Pin-8 of the IC as solder in the picture.
Step 7: Connect 6V Power Supply Wire
Solder +ve wire of Power supply to Pin-8 and
-ve wire of battery to Pin-1 of the IC as shown in the picture.
NOTE : Give 6V Input Power supply.
Step 8: Circuit Is Completed
Now our circuit is completed.
How circuit is working -
When we will touch wires of Pin-1 and pin-2 then LED is glowing and For Turn OFF of the LED we need to touch wires of Pin-8 and Pin-6 of the IC.As you can see in the pictures.
If you want to make more electronic projects then follow utsource123 now.
Thank you
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
