How to Make VU Meter Using Transistor
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make a VU Meter circuit using only one transistor.In this VU Meter I will use 2N2222A Transistor.This VU Meter is not good as compare to 3915 IC VU Meter.
Let's get stated,
Teacher Notes
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - 2N2222A x1
(2.) LED - 3V x6 (Any color)
(3.) Resistor - 1K x6
(4.) aux cable x1
(5.) Zero PCB
(6.) Battery - 9V
(7.) Battery clipper
Step 2: Transistor - 2N2222A
This is the pinout of this transistor.
Pin-1 is Emmiter,
Pin-2 is Base and
Pin-3 of this transistor is Collector.
Step 3: Connect All LEDs
Put all LEDs on the Zero PCB and Solder it's legs in series.
Step 4: Connect LEDs in Series
Solder +ve leg of one LED to -ve leg of another LED as solder in the picture.
Step 5: Connect 1K Resistors
Next we have to connect 1K resistors to +ve legs of all LEDs as you can see in the picture.
Step 6: Connect Other Side of Resistors
Solder all out wires of 1K Resistors to each other. {Connect all pins of other side of 1K Resistors} as you can see in the picture.
Step 7: Put Transistor
Next we have to connect the transistor to the PCB.
Connect Collector pin of transistor to the -ve legs of all LEDs as solder in the picture.
Step 8: Connect Aux Cable Wire
Next we have to connect aux cable wire to the circuit.
Solder +ve wire {Left/Right} of aux cable to the Base pin of Transistor and
Connect -ve wire {GND} of aux cable to emmiter pin of the transistor.
Step 9: Connect Battery Clipper Wire
Now we have to connect battery clipper to the circuit.
Connect +ve wire of battery clipper to Out {Other side of 1K Resistor} Side of the 1K Resistor and
-ve wire of battery clipper to Emmiter pin of the transistor as you can see in the picture.
Step 10: How to Use VU Meter
VU Meter Shows the audio level of the music.
Connect 9V Battery to the Battery clipper and Plug-in aux cable to the phone/laptop/tab..... and play songs.
Now As music will play like that LEDs will glow.
This type we can make Only One Transistor to VU Meter circuit.
Thank you
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
