How to Make a 18650 Lithium-ion Battery Charger
Introduction: How to Make a 18650 Lithium-ion Battery Charger
About: I make diy and electronics based projects.
In this instructables I will show you how to make a 18650 battery charger
Teacher Notes
Step 1: More Details in This Video
Step 2: Take a Paper Clip
Take a paper clip and take a part of the clip and bend like shows in the image
Step 3: Soldering Paper Clip
Take a pcb and take a 18650 battery as a measurement and mark it.solder paper clip well.
Step 4:
Take a thin steel wire and place it on sides of battery. Then make another one like that.
Step 5: Mark + and -
Step 6: Tp4056 Module
Tp4056 module is the main part of our project.glue module to pcb by using hot glue or double side tape. Connect b+ to positive of battery and b- to negative of battery.
Step 7:
Now it's ready to charge battery. Simply place battery inbetween the paper clips and connect any 5v power source here Iam using my diy power to charge the batteries.
Creative Misuse Contest
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    4 Discussions
    MajidA41
    MajidA41
    Question 1 year ago
    How log it take to charge and is it charging fully to 100%
    Electro maker
    Electro maker
    Answer 1 year ago
    It generally takes about 4 hours to charge an 18650 mod battery using a separate charger. If you use a Micro USB charger, it is likely to take about three hours. However, be advised that there can be some slight variance in charging times, even for a new battery.
    zolv
    zolv
    1 year ago
    I really like Your battery stands! I will definitely use Your idea in my project(s). Thx.
