How to Make a 3D Moon
About: Laser professor
The Moon is an astronomical body that orbits planet Earth and is Earth’s only permanent natural satellite. Today i gonna show you how to make a wooden moon.
Toady is going to use a Thunder Laser system to make a wooden moon. Let’s start to explore fun with the laser!
Supplies:
Material: 3mm plywood
Other items: some glue
Laser head: standard head
Laser cutting machine: Nova35 80watt
Step 1: Setting Parameters:
Processing Mode:
Cutting speed: 40mm/s
Cutting power: 70%
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser cutting machine.
Step 2: Assemble It:
Place the plywood on the work table of the Laser cutting machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Collect all the pieces cut out, Let’s do it by yourself.
    • Games Contest
      Games Contest
    • Planter Challenge
      Planter Challenge
    • Stone Concrete and Cement Contest
    Penolopy Bulnick
    4 weeks ago
    I think it's neat how the pieces notch together :)
