How to Make a Car & Caravan
About: Laser professor
Are you worried about your child’s toys? Now we have a Car & Caravan, which may make him interested in civil engineering.
Now is going to use a Thunder Laser system to make a Car & Caravan. Let’s start to explore fun with the laser!
Supplies:
Material: 3mm plywood
Other items: some glue
Laser head: standard head
Teacher Notes
Step 1: Setting Parameters:
Processing Mode:
Cutting speed: 40mm/s
Cutting power: 50%
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser cutting machine.
Step 2: Assembly It:
Place the plywood on the work table of the Laser cutting machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Collect all the pieces cut out, Let’s do it by yourself.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
