How to Make a Digital Thermometer #1
About: someone who likes electronics
In this article I will make a project called "Digital Thermometer". I use "DHT11" for the temperature sensor. And use the "7Segmrnt Module" as the display.
I recommend reading this article first "DHT11" and "7-Segment Module". In that article I have explained how to use DHT11 and 7Segment Module
Teacher Notes
Step 1: Required Componens
Here are the components that we need in this project:
Required Library:
Step 2: Assemble All Components
See the picture above for guidance on assembling the components. Or see the information below:
Arduino to 7Segment Module
+5V => VCC
GND => GND
D12 => DIN
D11 => CLK
D10 => CS
Arduino to DHT11
+5V => +
GND => -
D2 => out
After all components are connected, let's proceed to the programming section
Step 3: Programming
Below is a sketch that I used in this project or tutorial. You can use this sketch for your project.
<p>#include "DHT.h"<br>#include "LedControl.h"</p><p>#define DHTPIN 2
#define DHTTYPE DHT11 </p><p>LedControl lc=LedControl(12,11,10,1);</p><p>DHT dht(DHTPIN, DHTTYPE);
void setup() {
  Serial.begin(9600);
  Serial.println(F("Digital Thermoeter"));
  dht.begin();
  lc.shutdown(0,false);
  lc.setIntensity(0,8);
  lc.clearDisplay(0);
}</p><p>void loop() {
   delay(2000);
   float h = dht.readHumidity();
   float t = dht.readTemperature();
   float f = dht.readTemperature(true);
   if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
   float hif = dht.computeHeatIndex(f, h);</p><p>   float hic = dht.computeHeatIndex(t, h, false);</p><p>   Serial.print(F("  Temperature: "));
   Serial.print(t);
   Serial.println(F("°C "));</p><p>   delay(1000);
  char i = t;
  lc.setDigit(0,3,t/10,false);
  lc.setDigit(0,2,i%10,false);
  lc.setChar(0,0,0b1100,false);
  delay(400);</p><p>}</p>
after the sketch is finished, click upload and wait for it to finish.
I also provide sketches in the form of ".ino" files. The file can be downloaded below.
Step 4: Result
See the picture above to see the results.
for this project I only display the Celsius temperature only. For Fahrenheit temperature and humidity level, I will make the next article.
Thank you for reading this article, if you have questions, please write in the comments column.
See you in the next article.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
