How to Make a Flying Mr. Instructable
About: My name is Michael I am 14 and live in middle Tn, I am a 3d printing CNC machining Drone flying maker. Ever since into digital fabrication 3 years ago I have been learning and trying since.
This is a neat project that is very simple and fun to make. The inspiration for this project came while i was browsing Instructables and realized that the Instructables robot would make a great airplane. This is a simple project that anyone with a little patience can accomplish. I recommend some prior experience building RC airplanes.
My goals for this project where:
Easy to build
Fast build time
A fun project
Supplies:
Start by collecting your materials:
1 sheet of foam board
Red yellow and black spray paint
Electronics:
1806 motor
4in propeller
10amp ESC
x2 servos (any size under 9g)
450mah 3s battery
Tools:
Hot glue gun
Soldering Iron
basic hand tools (Knife, screwdrivers, etc...)
Teacher Notes
Step 1: Design and Cut
To start the assembly start by drawing a Instructables robot onto a sheet of foam board.
For mine, I drew it in fusion 360 and cut it on a X-Carve CNC machine. Since most people don't have access to a CNC I recommend printing a screenshot of the robot and drawing a simple robot directly onto the foam board. With that completed cut it out with a knife. Painting is where this project will really come to life. For mine I chose the standard yellow red and black but feel free to use your imagination.
1. draw design on to foam board.
2. cut the design out with a sharp knife
3. paint however you like it
Tips for painting!
When spray painting foamboard it is crucial to only put on light coats and not over spray. Over spraying the paint onto the foam will make it warp and peel.
Step 2: Glue Together
With all the pieces cut out and painted it is now time to start assembly.
With projects like this that are not completely symmetrical it is helpful to make a reference line down the center and make thing symmetrical to that. If you don't, there is a good chance that the parts will not be parallel and it will not fly well. I don't have plans but if you follow the pictures and make sure to keep everything square you should not have any problems.
Step 3: Electronic and Finishing
Now that you have the frame built it is time to add electronics and make it RC.
Electronics:
1806 motor
4in propeller
10amp ESC
450mah 3s battery
The motor mounts onto the front of the pod with a 3d printed mount. Glue in the servos about in the middle and Velcro the battery behind the motor. one of the most important parts in this step in getting the ballance right. With most airplanes you want the CG (Center of Gravity) to be 1/3 of the wing back.
You should now have the airplane built and painted. All the electronic should also be mounted and the CG set.
Make sure that all the servos are moving the correct direction and the motor spins the right way. I did not show all the electronics wiring because there is already so much about that online.
With that, you should be finished and ready to fly.
If you liked this Instructable please vote for it!
Please leave comments as to what can be done better.
Make It Fly Challenge
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    seamster
    13 days ago
    Clever, I like it! : )
