How to Make a Key Hook in Tinkercad
Introduction: How to Make a Key Hook in Tinkercad
4 round parts
5 squares
and 2 custom bolts
that i made
part is called Quick sketch.stl
Teacher Notes
Step 1: Step 1 Creating the Base
take 1 square and make it 80x130x8mm
then take the other square and make it 80x130x5
then take the last one and make it 5x5x130
then align them so it looks like this
Step 2: Step2: Creating the Hook
make 3 of the 4 cylinders into size 10x10x36
and the last cylinder will be hole piece and it will be 5x5x100
Image above
then group it
then allign it with the model
it should look like this
Step 3: ALIGMENT Photo
Step 4: Step 4 Support and Screw Hole
To make the supports you need to use 2 box parts and make them both 100x5x5 and angle it at 45 degres
you might have to use hole to cut away the excess on top then align them like this
The sccrews are optimal but i just took out 2 screws and put them like this
Step 5: Step 4 Picture
then you can group
thats it
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    Penolopy Bulnick
    Penolopy Bulnick
    7 weeks ago
    Thanks for sharing your Tinkercad project :)
