How to Make a Lamp With Paper and CDs
2,284
21
4
To make this lamp you will need following material:-
Balloon, Paper, PVA Glue, Water, White Distemper Paint, CDs (Used), Glue, Bulb Holder, Wire, Chain, Pencil, Detail Knife, Scissors.
Teacher Notes
Step 1: Basic Structure
Take pieces of paper and paste it on the balloon. Use mixture of PVA glue & water for paste. Let it dry. Remove the balloon from the Lamp.
Step 2: Make the Shape
Draw the design on the lamp and cut out. Make a small hole on the top side of lamp. Paint vase with white distemper paint and let it dry.
Step 3: Decoration of Lamp
Collect used CDs and cut these CDs in different pieces. You can cut CD through scissors or pliers. Now take these pieces of CD and paste it on the lamp. Use glue for paste.
Step 4: Fitting of Chain & Bulb Holder
Make three small holes (for passing of wire) top side of the lamp. Now take two pieces of wire and pass it on the said three holes. Take chain and pass it in the wire and join the both wire. Take bulb holder and pass its wire on the small hole of lamp.
Paper Contest
Paper Contest
Be the First to Share
    • Fashion Contest
      Fashion Contest
    • Reuse Contest
      Reuse Contest
    • Hot Glue Speed Challenge
    4 Discussions
    jessyratfink
    8 months ago
    That looks fabulous! And that's a great way to hang it, too :)
