How to Make a Magnet Generator
This magnetic generator can power a light. You spin the nail, the magnets go around, and the light bulb lights up. Try it! Make sure you have all the materials before you start. Don't substitute them! Try making this cool generator.
Teacher Notes
Step 1: What Do You Need?
You will need:
  • Cardboard 8cm x 30.4cm
  • 4 - 1x2x5cm ceramic magnet
  • 1 - #30 Magnet wire 200ft
  • 1 - Miniature Lamp, 1.5V 25mA Rad
  • 1 - Large nail, 8cm long or more
  • Sandpaper to strip the wires
Step 2: Building Your Frame
Your cardboard needs to be 8 cm tall by 30.4 cm long.
Score the cardboard at 8 cm, 3.5 cm, 8 cm, 3.2 cm, 7.7 cm.
Then fold into a box and tape.
Step 3: Finishing Your Frame
Puncture a hole in the middle of the box, then stick the nail through the holes.
Make sure the nail goes all the way through the box.
Make sure the nail can spin freely.
Step 4: Wiring
Take out your nail.
Tape the end of the wire to the box.
Wrap the wire around the box about 250 times.
Make sure it fits comfortably without coming off.*
Use sandpaper to scrape off both ends of the wire.
If your wire breaks, use sandpaper to strip the ends of the wire where it snapped, and twist together.
*If you wrap the wire too tight, it will collapse the box.
Step 5: Magnets
Put the nail back in.
Hot glue two magnets (stacked up) to each side of the nail.
Do not tape the magnets. It disrupts the flow of electricity.
Step 6: Test It!
Twist the ends of the wire to the ends of the light.
Spin your nail.
If you spin your nail fast enough, the light should light up.
Step 7: Why It Works
It works because there is wire surrounding the magnets. When the magnets have wire around them, there is pressure. It is called voltage. The faster you spin the magnets, the more voltage you have. That is why the light lights up.
Make it Glow Contest 2018
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    4 Discussions
    audreyobscura
    9 months ago
    Hey there, Welcome to Instructables!
    This project is a great idea, but it doesn't look your video file is working. I'd love to see this in action so it can be let into the Make it Glow Contest.
    Maybe consider uploading your video to a service like YouTube and embedding the video module into step 6 above to demonstrate the effect? Can't wait to see this project in action.
    Let me know if you need help with your video upload.
    Cheers! -audreyObscura
    scolbreseaudreyobscura
    Reply 9 months ago
    We have fixed the video, if you could review the video and get back to us, that would be great. Thanks!
    TheAlienContainmentsJ
    9 months ago
    Beautiful! 10/10 would recommend to others! I love it! (づ。◕‿‿◕。)づ
