How to Make a Optocoupler (Vactrol)
4,227
9
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with.
This is a short ‘ible on how to make an Optocoupler. There’s a whole bunch of names that this little electric component comes under. Others include vactrol, Opto-isolator, photocoupler and optical isolator.
An optocoupler allows you to transmit an electrical signal between two isolated circuits with two parts: an LED that emits infrared light and a photosensitive device (LDR) which detects light from the LED. Both the LED and the LDR are enclosed so no light can reach the LDR. The shop brought ones will be enclosed in plastic. This homemade version uses a small piece of heat shrink.
So what is an optocoupler and why do you need to know how to make one. If you build circuits then at some stage you will come across a weird schematic symbol that is a optocoupler. An optocoupler can be used in many applications such as synths and sound effect circuits, input/output switching, and a bunch of other applications.
Here's a couple of links for those who want to learn more about optocouplers
link 1
link 2
More Technical Link 3
Teacher Notes
Step 1: Identifying an Optocoupler in a Circuit
Below are some of the more common optocoupler schematic symbols you might come across. You can see that the symbol is made up of an LED and photoresistor symbol.
Actually, the symbol depicts what an optocoupler is quite well. I did find it a little confusing however when I first come across one as I didn’t realize they were connected parts
I have also added a couple of schematics that show you an optocoupler being used
Step 2: Parts and Tools
Parts List
1. 5mm LED – eBay
2. LDR – eBay
3. Heat Shrink 6 to 7mm – eBay
Tools:
1. Lighter
2. Scissors
Step 3: How the Optocoupler Goes Together
The images in this step shows how the components go together. You can see that the LED and the LDR face each other inside the heat shrink. The LED acts as an input and the LDR is the output receiver.
Step 4: Placing the LED and LDR Inside the Head Shrink
Steps:
1. First, grab your heat shrink and cut a 20mm piece
2. Next, Place the LED into the heat shrink. If you have troubles pushing the LED into the heat shrink due to the rim on the LED, you can remove it with a file.
3. Push the LED into the heat shrink so there's about 5mm over the LED legs.
Step 5: Shrinking the Heat Shrink
Steps:
1. Whilst holding the LED legs, start to add some heat to the heat shrink around the LED section
2. Make sue you only add heat to the section where the LED is as you only want the heat shrink to shrink around it.
3. Once the heat shrink has melted enough, use a pair of needle nose pliers to squash the heat shrink around the LED legs, effectively forming a seal. What you are trying to do is to seal any potential outside light reaching the LDR - you only want the light from the LED to affect it.
4. Do the exact same for the LDR.
Step 6: Bending and Cutting the Legs
Steps:
1. Take note of which leg is the positive on the LED. A good idea before you trim the legs is to snip a small corner away from the heat shrink next to the positive leg. This way you will always know which one it is.
2. Bend both the legs of the LED and the LDR down
3. Trim the legs on both the LED and the LDR
That's it. You have now made your own optocoupler which will work just as good as any store brought one.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    9 Discussions
    askjerry
    23 days ago
    That is a pretty good example of opto-isolation, but it does use a variable resistor. Typically a phototransistor is used which does a few of things that this model does not.
    1) It is very fast acting.
    2) It typically carries a bit more current.
    3) It can be triggered electrically if desired.
    Take a look at my favorite... the 4N35 optocoupler. You can connect the LED and the two phototransistor outputs... but there is also a base that allows for electrically switching the device on if desired.
    RE: https://www.vishay.com/docs/81181/4n35.pdf
    nqtronixaskjerry
    Reply 20 days ago
    Interesting part, I didn't know they make them with an exposed base connection.
    askjerrynqtronix
    Reply 19 days ago
    This is my "go to" part... I order 25 at a time. :-)
    nqtronix
    20 days ago
    Although your build does provide galvanic isolation, it is not a substitute for an optocoupler. Not only will the transfer function be different (ie. the same input current will not have the same effect on a real optocoupler), but it will be also about 100 times slower. Typically optocouplers are used in high voltage applications as a safety measure and thus must have a guranteed voltage rating, which your build doen't have either.
    So yeah, to understand the concept this is fine, but for real applications it won't work in the best case or be a risk for electric shock in the worst case.
    Gadisha
    22 days ago
    Interesting, thanks for sharing :)
    zpaeric
    24 days ago on Step 6
    I’m not an engineer, but optocouplers I know of use an LED and a photo transistor to get quick on and off( as shown in your schematic sample) Your part is using a Light Dependant Resistor which may give different results in a project. I would guess the photo transistor would work in your Instructable the same way though.
    BurgersBytes
    24 days ago
    An LDR is not a light activated transistor or diode, it is a variable resistance that has nothing to do with your schematics.
    Donald Bell
    26 days ago
    This is great! You have a few missing placeholder links at the beginning, though.
