How to Make a PVC Pipe Slide Whistle
1,057
7
Introduction: How to Make a PVC Pipe Slide Whistle
This instructable will teach you how to make an incredibly simple and cheap PVC pipe slide whistle that works pretty effectively.
Step 1: What You'll Need
This PVC instrument is pretty easy to make and requires few materials. Here's what is needed:
  1. A PVC pipe, at least 12" long. The great thing about this instrument is you can use any length and diameter of PVC that you want. For this we used a 12" PVC pipe with a 3/4" diameter
  2. A wooden dowel, that is a few inches longer than your PVC pipe. Try to get a dowel that matches the diameter of your PVC pipe so that the clearest sound is produced, we didn't have 3/4" dowels so we used a 1/2" one instead.
  3. A ruler
  4. PVC pipe cutters
  5. A hot glue gun (not pictured)
  6. A hand saw
  7. A coping saw
  8. A vise grip (not pictured)
Step 2: Cutting Your PVC Pipe
Now you'll cut the hole that will actually generate sound.
  1. Take your PVC pipe cutters, and chose an end to cut a hole in
  2. Its up to you how far from the end you cut the hole, and it can vary depending on the length of the pipe, but for this one we made the first cut 1 and 1/2" from the end
  3. Make the first cut vertical and go about halfway down the pipe
  4. Then make a second cut about an inch away from the first cut, this one at an angle so that it forms a curved triangle shape
You want to position this hole close to the end of the pipe so you will be able to generate as many notes as possible
Step 3: Making the Stopper
This stopper will be cut from the wood dowel and will go in the same end that you cut the hole in. This is where you will blow air in to the instrument to generate sound.
  1. Cut a segment of the wood dowel off, this segment should be as long as from the end to where you made the first cut for the hole in the last step, so for us this segment was 1 and 1/2" long.
  2. Very carefully cut about 40% of the dowel off using the coping saw so you have what resembles a semi-circle (as seen in the picture)
  3. Use the hot glue gun to glue the stopper in with the flat end facing towards the hole you cut
Step 4: Finishing the Instrument
Now all you have to do is stick the rest of the dowel in the end of the PVC pipe and it's ready to play!
It takes some practice to generate sound with the mouthpiece, but once you have it down it's easy to play and make a variety of different notes.
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    Alex in NZ
    Alex in NZ
    1 year ago
    Nice! All ready for a round of the great game "Swanee Kazoo". Thank you for sharing your work :-)
