How to Make a Peanut Butter & Jelly Sandwich
Introduction: How to Make a Peanut Butter & Jelly Sandwich
In this Instructable we will learn how to make a peanut butter and jelly sandwich (PB&J).
BEFORE BEGINNING:
If you have food allergies do not participate (check ingredients before beginning).
You may get messy, make sure you roll up your sleeves, and wash your hands.
Keep small children away from the knife if it is sharp.
Supplies:
To begin: make sure you have a plate, a knife, a loaf of bread (your preference on what kind, I am using Honey wheat in this instructable), a jar of peanut butter, and a jar or tube of jelly.
Teacher Notes
Step 1: Begin
First remove the bread bag twisty tie, and take 2 pieces of bread out of the bag.
Step 2: Prepare Sandwich Bread
Place the bread slices horizontally on the plate with the white of the bread facing up.
Step 3: Prepare Peanut Butter and Jelly
Next, Screw the top off of the peanut butter jar, and open the jelly container.
Step 4: Utilize the Peanut Butter
Take your knife, and scoop about a tablespoon (or preferable amount) of peanut butter on the knife.
Step 5: Apply the Peanut Butter
Spread the peanut butter evenly on one slice of bread (on the side that is facing up).
Step 6: Apply the Jelly
Once all the peanut butter is off of the knife, take the jelly, and squeeze a tablespoon (or preferable amount) onto the second slice of bread.
Step 7: Spread the Jelly
Spread the jelly with the knife evenly onto the second piece of bread (on the side that faces up).
Step 8: Finish Using Bread, Peanut Butter, and Jelly
Tie the bread bag up with the twisty tie, screw the lid onto the peanut butter jar, and close the jelly container.
Step 9: Combine the Sandwich Halves
Place the pieces of bread together sot that the jelly and the peanut butter are touching, and the clean sides of the bread are on the outside. When you look at your sandwich you should see from top to bottom: (bread, peanut butter, jelly, bread, plate).
Step 10: Cut the Sandwich
Now, you cut the sandwich into triangles by making a diagonal cut from the top right corner, across the middle, straight across to the bottom left corner. You should finish with 2 equal sized triangles.
Step 11: (Optional) Cut the Crust Off
If you do not like crust on sandwiches, you may choose to cut the crust off with your knife so that the entire perimeter is gone, and you only have the white of the bread left. (Make sure you are only cutting off the brown edge, nothing else.) You do not have to do this step if you don't want to.
Step 12: Eat the Sandwich
Enjoy your sandwich!
Be the First to Share
    • Baking Speed Challenge
    • Cardboard Speed Challenge
    • Indoor Plants Challenge
