How to Make a Peanut Butter and Jelly Sandwich
Introduction: How to Make a Peanut Butter and Jelly Sandwich
In this discussion, we will be demonstrating how to make a peanut butter and jelly sandwich. This snack or meal is easy, quick and affordable for kids and college students to enjoy. A peanut butter and jelly sandwich can be that go-to snack or meal when you want something filling without eating a full course meal. The only knowledge that you need would be how to use/operate a butter knife properly.
Safety Warning: If you are under the age of 7 years, we strongly recommend that you ask for parental help or supervision.
Health Warning:
If you have a peanut allergy, there are alternatives that can replace peanut butter. (Such as sunflower seed butter, wow butter, pea butter, etc.) If you have a gluten intolerance, bread can be substituted for a gluten free alternative.
Supplies:
Plate
Butter Knife (Metal/Plastic; Used Metal)
Napkins
Hand Soap Sink with a running faucet
Ingredients
Sandwich Bread (Enriched White/Whole Wheat/Gluten Free; Used Enriched White) - 2 slices
Peanut Butter (Creamy/Crunchy; Used Creamy) - amount varies, 1 Tablespoon Recommended
Jelly (Flavor of your liking; Used Grape) - amount varies, 1 Tablespoon Recommended
Optional a Drink of Choice (Milk, Water, Juice etc.)
Estimated Time: 5 minutes
Step 1:
Pull out 2 slices of bread and lay them side by side on a plate, or other clean surface, in front of you on a flat surface.
Step 2:
Grab your butter knife and scoop 1 tablespoon (or desired amount) of jelly
Step 3:
Spread jelly evenly on first slice of bread in a left to right motion.
Note- Make sure the jelly is covering the entire slice of bread from edge to edge
Step 4:
Use your napkin to clean off any excess jelly from the butter knife
Step 5:
Grab your butter knife and scoop 1 tablespoon (or desired amount) of peanut butter
Step 6:
Spread the peanut butter evenly on the second slice of bread in a left to right motion
Note-Make sure the peanut butter is covering the entire slice of bread from edge to edge
Step 7:
Quickly & carefully place the two slices of bread together, ensuring the crust of the bread slice is in line with the crust of the other slice.
Note- We recommend putting the peanut butter slice on top of the jelly as it has a thicker consistency and will allow for a cleaner placement.
Step 8: Optional
Cut off the crust of bread with the butter knife
Step 9: Optional
Cut the sandwich diagonally from one corner to the opposite corner/ Cut the sandwich vertically from top to bottom.
Note-Cutting the sandwich in different segments can create multiple sandwiches for people to enjoy.
Step 10:
Go to the sink and wash the supplies you used and then wash your hands with soap. Rinse and dry then turn faucet off
Step 11:
Proceed to put all the ingredients in the refrigerator and cabinets as well as the utensils used
Step 12: Optional
Grab a beverage of choice
Step 13:
Place sandwich and drink at location of dining and voila, you have created a peanut butter and jelly sandwich! Enjoy.
Step 14: Troubleshoot
Ripped Bread: If you find the peanut butter is ripping the bread instead of spreading, your peanut butter is to cold. Allow it to warm up to room temperature before attempting to put it on the soft bread. This is particularly important for crunchy styled peanut butter.
Soggy Sandwich: If your sandwich is soggy from the jelly, this could be from letting the sandwich sit too long before consuming. If you are making a sandwich for a later time and have this issue, we recommend putting a thin layer of peanut butter on both slices of bread before putting the jelly. The thick consistency of the peanut butter will protect the delicate bread from soaking the jelly.
Step 15: Citiations
How to Make a Peanut Butter and Jelly Sandwich. (n.d.).
Retrieved from https://www.wikihow.com/Make-a-Peanut-Butter-and-...
How Eating Peanut Butter And Jelly Can Make You A Millionaire. (2018, January 05).
Retrieved from https://letsbemillionaires.com/how-eating-peanut-...
Big PB&J Sandwich. (n.d.).
Retrieved from https://www.eatthismuch.com/recipe/nutrition/big-p...
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
