How to Make a Pumpkin Prop
106
About: A shop offering over 5,500 model making materials, tools and accessories for all 3D design disciplines including architecture, theatre set design, animation, product & interior design, prop making, cospl...
The method below examines how we went about the task.
There is a full list of materials used, all are available from our website www.modelshop.co.uk
Supplies:
500mm polystyrene sphere (SB91028)
UHU Por Styrofoam adhesive 40g (AP00022)
Retractable craft knife (TK10039)
Sandpaper (60/70 grit) (TA10000)
Foamcoat 500ml (FT03005)
plus an orange emulsion/acrylic paint of your choice.
Teacher Notes
Step 1: Glue & Divide
Glue the two halves of the sphere using UHU Por Styrofoam adhesive.
Draw on the segments of the pumpkin, dividing in half, then quarters, then eighths, then sixteenths.
Step 2: Press & Score
Flatten the sphere on the top by applying gentle pressure.
Using a craft knife cut grooves into the pumpkin following the drawn lines.
Step 3: Sand & Coat
Gently sand the grooves to smooth them using a course sand paper.
Seal the pumpkin using watered down PVA glue (AP00037) , Foam Armour (FT03006) or Rosco foam coat (FT03005).
Step 4: Sand & Seal
When dry, sand the surface to smooth out the larger imperfections.
Using a filler fill the joint. When dry sand and then seal.
Step 5: Undercoat
Apply an undercoat to the pumpkin preferably using an emulsion type paint.
Step 6: Create a Smooth Surface
When painted fill any areas that are not smooth then sand, seal and paint.
Step 7: Apply Top Coat
Apply a coat of Acrylic paint to give solid satin finish.
Step 8: Shade the Grooves
Using the acrylic orange darkened with a small amount of black paint to use as shading in the grooves.
Step 9: Finishing Touches
A shaded pumpkin.
Dress the pumpkin with a stork, leaves and tendrils.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    3 Discussions
    snowf7
    Question 1 day ago
    Could this be done with an old basketball?
    1 answer
    4D modelshopsnowf7
    Answer 1 day ago
    Hi, thanks for your interest. We used the polystyrene sphere as it can be squashed slightly to give a more pumpkin shape. We can also carve into it. Don't think this will work with a basketball.
