How to Make a Rechargeable Led Emergency Light
Introduction: How to Make a Rechargeable Led Emergency Light
About: I make diy and electronics based projects.
In this instructables I will show you how make a rechargeable led emergency light using couple of old laptop batteries.
Teacher Notes
Step 1: More Details in Video
Step 2: Components Needed
1) plastic box
2) female micro usb
3)led
4) switch
5)10 ohm resistor
6) in 4007 diode
7)2× 18650 battery
8) 4v led panel
9) 1 ohm resistor
Step 3: Holes for Components
First I make a perfect holes for usb,led,and switch then attached.
Step 4: Wiring
Connect usb wire to led indicator through a 10 ohm resistor then take a 1n 4007 diode and connect to positive wire of usb then connect both positive and negative wire to the battery next step is connecte battery positive to switch and battery negative to a 1ohm resistor then connect that to wire to led panel. Wiring is finished.Take a plastic sheet glued to the top of the box and glied the led panel to the top of the sheet
Step 5: Charging
Note: use tp4056 module to charge the batteries.
Creative Misuse Contest
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
