How to Make a Retro Poster
281
7
Introduction: How to Make a Retro Poster
Hi, I am John and I love digital art. I like to create all kind of graphic design resources (https:…
In this tutorial I will show you how to make a retro poster in just a few easy steps. To make this cool retro poster we need these resources:
Step 1: Add the Car Silhouette
Create a new layer called Background and fill it with color white.
Download the car silhouette pack that includes CSH, ABR and PNG files. For this tutorial I will use the custom shapes, so load the CSH file in Photoshop. Add the car silhouette and use color black.
If you are using other software you can use the PNG files included in this pack.
Step 2: Merge the Layers
Press Shift+Control+Alt+E to make a copy of all the visible layers. Call this layer Car Background and fill it with color white.
Step 3: Remove the White Background
Use the Magic Wand Tool to select the white background. Press delete to remove the white background.
Place the Car Background layer below the Car Silhouette layer.
Step 4: Add the Sunburst Background
Add the Sunburst Background in a new layer below the car layers. Resize and rotate by 90 degrees the background.
Step 5: Add the Retro Text
Add a rectangle shape using the Rectangle Tool. Pick the color #a32b2b for the shape.
Add a text using a font that you like. I used League Spartan font, but you can choose a retro font that you like. The color for the text is white.
Step 6: Add the Dust Texture
Select the Car Silhouette layer and the Text layer and put them in a group. Add a Layer Mask to this group.
Add the Dust Texture above this group. Click on the Layer Mask of the group and go to Image > Apply Image.
Press Control+I to invert the mask. Then you can delete the Dust Texture layer.
Step 7: Use a Levels Adjustment to Sharpen the Mask
Go to Image > Adjustments > Levels and sharpen the dust texture mask to obtain a grunge effect.
Step 8: Add the Old Paper Texture
Add the old paper texture in a new layer. Set the blend mode to Multiply.
Step 9: Add the Grunge Texture
Add the grunge texture in a new layer. Set the blend mode to Soft Light. Also add a Levels adjustment. Right click and choose Create Clipping Mask.
Step 10: Add a Border
Create a new layer and call it Border. Fill the layer with color white. Set the Fill to 0% and add a Stroke layer style. The color of the border is #e3c79f with 80% opacity level.
Step 11: Retro Poster Final Result
So, here is the final result for the grunge retro poster.
I made this poster in Photoshop. But, you can use the same images to obtain the same result using other software like Gimp, Photopea, etc.
Be the First to Share
    • Recycled Speed Challenge
    • Make it Move Contest 2020
    • Build a Tool Contest
