How to Make a Sock Bunny
28
Introduction: The purpose of these instructions is to teach an easy way to make a sock animal. Once you are finished you can gift is to a child, or even show them how to make a sock animal for a fun crafting project.
Step 1: Get Materials
  • Socks
  • Poly-fil (you can use stuffing from an old pillow or cotton balls)
  • Tiny Rubber Bands
  • Scissors
  • A Hot Glue Gun or Makers (for decorating)
  • Other Decorative Items
Step 2: Grab a Sock
Flatten a sock so that the heel part of the sock is facing up, and the open end of the sock is at the top.
Step 3: Make the Legs
Roll a wad of poly-fil (or cotton balls) into a ball about one inch in diameter and out it inside of the sock at the very bottom right-hand side. Use your finger to press the ball from the inside of the sock tight against the side of the sock, the grab the ball from the outside of the sock and wrap a rubber band around the ball to form a foot. DO the same thing on the other side.
Step 4: Make the Arms
Roll up two more wads of poly-fil and stick them about two finger lengths down from the heel to form arms just like you did with the feet.
Step 5: Stuff Your Bunny
Fill the sock with poly-fil all the way up to where your heel would go. If you want a bigger bunny add more poly-fil.
Step 6: Secure the Stuffing
Place a rubber band right above the arms to form a neck, and one at the top where your poly-fil ends to close it making a head.
Step 7: Cut
Cut off half of the cuff of the sock (less if you want bigger bunny ears) by cutting horizontally with the bunny standing up. The cut the remaining part vertically down the middle.
Step 8: Form the Ears
Spread out both halves of the cuffs, take the left cuff and cut from the top point on the left down to where the rubber band is, making a curved ear. Repeat on the right side.
Step 9: Decorate!!
Decorate Your Bunny! Color in the ears by going in about 2 centimeters in from the outside diameter and filling in the open white space. Use a glue gun or maker to add the eyes, nose and mouth.
Step 10: You're Finished
Now you have a stuffed bunny, you can add more to it if you want. You can even make clothes out of the scraps that you cut off. Be creative.
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
