How to Make a Timer by Yourself
About: Love learning, love life, love traveling
Timers are now widely used in many applications, such as electric vehicle charging with timing charging protection, and some functional networking timing controllers. So how do you make a timer?
Teacher Notes
Step 1: Material Tool Preparation
1, a plastic case 1
2, timing controller 1
3, 1 input and output power interface
4, other wire tools, etc.
For some electronic components parts, we can buy fromjotrinone of the best global electronic components distributors or some other famous online shops, it's up to you
Step 2: Installation Input Socket
Install the 8-shaped power socket in the original empty slot of the plastic box, just the right size and open the hole in the lower-left corner of the front panel for installing the USB socket as the power output interface.
Step 3: Switching Power Supply
Adjust the installation position of the switching power supply
Step 4: Cutting Board
Solder the USB busbar to the universal board, and solder the connecting wires of the positive and negative poles to cut the appropriate size for easy installation.
Step 5: Glue Fixing
Install the USB socket, adjust the corresponding position, and fix the whole small module with hot melt adhesive.
Step 6: Test Location
The fixed USB socket is filled with hot melt glue to fill the empty slots, and the modules are welded and connected. After soldering, the test position is just right and the size is just right.
Step 7: Button and Buzzer Hole
The upper panel opens the hole according to the position of the corresponding component, first opens the hole of the digital tube, and then continues to open the hole of the button and the buzzer position.
Step 8: The Effect After Closing the Lid
Close the upper panel and complete the overall production
Step 9: Plug Identification
The power-on test works perfectly, and finally, the screw can be used, and the production is over. Attach the operation button logo and the label next to the input and output plug.
Step 10: Completed Successfully
The effect that has been completed, the power-on state, the overall looks very simple and generous.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
