How to Make a Wheelie Bar for Bikes
1,002
Introduction: How to Make a Wheelie Bar for Bikes
About: Brought to you by the Kuality Racing Team, we're the ones that put the 'K' in Kuality.
  • Can be made in a few hours
  • Install or remove in minutes
  • Total cost $10
I've always wanted to ride a LOOONNNGGG wheelie, hopefully this will help.
Parts list
  • 2" schedule 40 pvc pipe (grey and white were tested side by side, grey seemed slightly stiffer and looks better)
  • 45 degree 2" union for the scuff guard
  • zip ties
Tool List
  • Drill press (Harbor Freight $65)
  • Bevel gauge
  • 1" paddle bit (my seat post is 1")
  • 'Rasp' drill bit or files
  • Saw that will cut plastic
Teacher Notes
Step 1: Find Balance Point & Drill Seat Post Hole
Find Balance Point
Sit on the bike with the back brake on, front wheel on a chair and leaning against a wall. Keep adding spacers under the front wheel until you reach your balance point, for me it was two reams of paper.
Measure
Hold the PVC pipe in place with tape, rubber bands, or bungee cords. Mark where to make the seat post hole so that the tail of the pipe will be a few inches longer than needed, you can always cut it shorter later.
A drill press is recommended for this step, it is difficult to drill a hole at an angle through plastic with a hand drill. Use a bevel gauge to measure the angle of the seat post to the pvc pipe. Set the drill press to the same angle. Drill the hole. Use a rasp bit or file to adjust the hole until the seat post will fit snugly through it.
Tip: practice drilling the seat post hole in the front of the pipe, it will not be used.
Step 2: Pipe Cut Front & Final Assembly
Cut Pipe to Fit Front
Cut the pipe at an angle where it will meet the head tube so it won't rub on the headset, making it ~1/2" longer than necessary. I drilled an angled hole with the 1" paddle bit then used small one-hand bolt cutters to slowly trim it bigger until the seat post hole lined up. If I had to do it again I think I would skip the hole and just use the bolt cutters to trim until it fits.
Final Assembly
Use a zip tie in front and one in the back to hold it in place. Press fit (don't glue) a 45 degree union scuff guard on the end and go for a test ride! If it's too long just trim the end.
Caster?
My original plan was to mount a caster on the 45 degree union but decided it would look ridiculous. The scuff guard is holding up well so far, and they are only $2.
Be the First to Share
    • Trash to Treasure Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
    2 Discussions
    JesseK13
    JesseK13
    1 year ago
    Nice. Has it worked?
    kelpchex
    kelpchex
    Reply 1 year ago
    It works, I just need to practice more. Wheelies are tough, I can ride a unicycle for a couple hundred yards and can only wheelie for 30 feet.
