How to Make a Wooden Aircraft
Introduction: How to Make a Wooden Aircraft
About: Laser professor
Small aircraft are one of the toys that many children like. It seems that everyone has a dream of flying, and now we can achieve it.
Toady is going to use a Thunder Laser system to make a wooden aircraft. Let’s start to explore fun with the laser!
Supplies:
Material: 3mm plywood
Other items: some glue
Laser head: standard head
Laser cutting machine: Nova35 80watt
Step 1: Setting Parameters:
Processing Mode:
Cutting speed: 40mm/s
Cutting power: 70%
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser cutting machine.
Step 2: Assemble It:
Place the plywood on the work table of the Laser cutting machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Collect all the pieces cut out, Let’s do it by yourself.
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
