How to Make a Wooden Globe
Introduction: How to Make a Wooden Globe
About: Laser professor
Will a flat map make you bored? If so, let us make a globe.
Now is going to use a Thunder Laser system to make a wooden golbe. Let’s start to explore fun with the laser!
Supplies:
Material: 3mm plywood
Other items: some glue
Laser head: standard head
Laser cutting machine: Nova35 80watt
Step 1: Setting Parameters:
Processing Mode: Cutting speed: 40mm/s Cutting power: 50%
Engraving speed: 100mm/s Engraving power: 15%
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser cutting machine.
Step 2: Assemble It:
Place the plywood on the work table of the Laser cutting machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Collect all the pieces cut out, Let’s do it by yourself.
laser cutter
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
