How to Make a Working Water Dispenser
Introduction: How to Make a Working Water Dispenser
About: I like crafting and making stuff
If your having a party, want to stay hydrated, bored, or just want this for your room this is the perfect DIY for you!
Teacher Notes
Step 1: Materials
For this project you will need a hot glue gun, paint (optional), cardboard, scissors or box cutter, a sharpie, paint brushes, an empty bottle of water, and a straw.
Step 2: Making the Stand
Using your cardboard cut out one square with a semi circle on top (the square part is L=3 in W=8 cm), three rectangles (L=2 1/2 in W=2 in), and one square (L=2 1/2 in W=2 1/2 in).
Step 3: Gluing the Pieces
Place the square with the semi sphere on the table. On the top hot glue the rectangles with about one inch in between. As best as you can center the square on top and apply glue.
Step 4: Preparing the Water Tank
Take the plastic bottle and cut a hole near the bottom. Take your straw and cut it to about 8 cm on the bendy side. Hot glue the straw bendy side out to the inside of the hole in your bottle.
Step 5: Gluing the Stand to the Water Tank
This step is pretty self explanatory because all you do is hot glue the bottom of the bottle to the top of the square on the base.
Step 6: Making a Border
Make a Square that's a couple inches longer and wider than the stand. Measure each side of the square and mark on cardboard the width, and then a make your length a little less than a foot long. On the side with the straw cut out a hole so the straw can pass through. Finally hot glue the base to the top of the square, and hot glue each piece to its matching side.
Step 7: Customizing
You can paint the border, duct tape it, add stickers, leave it blank it really doesn't matter as long as it's what you want.
I hope you enjoyed this tutorial and have a great day!
Water Contest
Water Contest
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    11 Discussions
    Reasonstacy
    Reasonstacy
    Question 10 months ago
    What is the hypothesis of a water dispenser
    JiizZ
    JiizZ
    Question 1 year ago on Step 7
    what action is happening when i open the bottle and close it again
    SavageSydTheKid
    SavageSydTheKid
    Answer 1 year ago
    The water flows out when you open the cap due to air pressure. When the air pressure enters the bottle, the water is being pushed out.
    CollinF6
    CollinF6
    Tip 1 year ago on Step 7
    How do you get the water out dude ?
    SavageSydTheKid
    SavageSydTheKid
    Reply 1 year ago
    Sorry I guess I forgot to mention that part, so you get the water out by screwing the lid of the bottle off. If you want to stop it from dispensing simply screw the lid back on.
    CollinF6
    CollinF6
    Reply 1 year ago
    Do not have a hot glue gun what can I use instead ?
    SavageSydTheKid
    SavageSydTheKid
    Reply 1 year ago
    Again I’m sorry for the wait, but you can use nor normal glue (aka/ pva glue) you just might have to hold the parts in place with your hands or position them with an object for a little.
    jackbeast78
    jackbeast78
    Question 1 year ago
    What does this have to do with winter?
    SavageSydTheKid
    SavageSydTheKid
    Answer 1 year ago
    I think you might have thought that the contest was winter instead of water
    jackbeast78
    jackbeast78
    Reply 1 year ago
    Sorry my bad.
    SavageSydTheKid
    SavageSydTheKid
    Reply 1 year ago
    It’s okay everyone makes mistakes ;)
