How to Make an Ocean-plait Mat
722
15
Introduction: How to Make an Ocean-plait Mat
To make an ocean-plait mat you will need:
  • About 8.2m of rope with roughly a 10mm diameter
  • A needle
  • Thread the same / a similar colour to your rope
  • A knife (preferably a hot knife but it doesn't matter too much) to cut the rope
Teacher Notes
Step 1:
Tie an overhand knot near to one of the ends of your rope.
Make the loops bigger as shown in the picture.
Add twists to the loops twisting from the bottom to the top of the loop.
Cross the two loops over each other (top loop over the bottom loop).
Step 2:
Thread the short end of the rope back through the loops as shown (under, over, over, under).
Thread the long end of the rope back through the loops (over, under, over, under, over).
Step 3:
Thread the long end of the rope back around through where the short tail exits the knot.
Follow the path of the rope until you have a doubled up knot.
Step 4:
Now you have the knot doubled up, keep going round the knot following the path of the rope so you have the knot tripled up.
Repeat a final time until there are 4 ropes side by side going around the knot.
Step 5:
You now have a completed knot, however it still has the 2 tails hanging out the side.
To make the knot neater you can cut off the tails using a knife and then use a needle and thread to secure them to the knot.
Congratulations, you now have a completed ocean-plait mat!
Rope & String Speed Challenge
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Trash to Treasure Contest
    • 3D Printed Contest
      3D Printed Contest
    3 Discussions
    kredytowy
    kredytowy
    5 weeks ago
    It looks very nice. Unfortunately, it wasn't easy to do it :)
    bakichmg
    bakichmg
    Question 6 weeks ago
    That is really nice. Would you be able to put a ruler or something by it in a photo to get an idea on it's size please??
    Oli H
    Oli H
    Reply 6 weeks ago
    Thanks! Its dimensions are roughly 30cm x 20cm
