How to Make the Cabinet of Defense
Introduction: How to Make the Cabinet of Defense
In this tutorial I will show you how to make the Cabinet of Defense or a Cabinet Shield if you will
Supplies:
1. spare plywood
2.screws of varying sizes
3.a drill and drill bits (For pre-drilling screw holes.)
4.a jig saw or circular saw for cutting wood
5.screwdrivers(" just in case.")
6. some strapping
7. a long 1 inch dowel rod
8 . a old wood medicine cabinet
Step 1: Finding a Old Wooden Medicine Cabinet
personally I know not every one has one of these at least that there not using more than likely at some point or another but check the trash on a renovation site they might let you have it if they are throwing it out. I happened have mine in the basement
Step 2: Take Off the Door
in this step use your screwdrivers to carefully take the door & door hinges off. Also take any shelving and shelving parts out of your cabinet while doing this.
(save the door hinges for later on.)
Step 3: Replacing Wood
turnover your cabinet and take the thin board off . measure and cut new plywood and screw on the new like in the pictures above but when doing this DO NOT screw in the bottom side
Step 4: Take Off Bottom
find the bottom board and take it off and make recesses for the hinges that will go back on later
Step 5: Build the Front Handle
take your dowel rod measure and cut it so you can mount it on the side walls
Step 6: Mounting the Main Front Handle
once you get the dowel handle where you want it. Take screws and mount it
Step 7: Mounting the Bottom Door
take the bottom you took off and put your hinges on it and mount the bottom like the picture above while making it opens flat and closes into a box
Step 8: (optional) Paint or Stain
i had to paint after i scraped a lot of old paint off
Step 9: Arm Strapping and Finishing
measure your arm and cut some strapping to length to bolt on a strap with washers and screws onto the shield to hold your arm steady then try it out
Step 10: Hang It Up or Use It
when the need arises it will be ready or take it down and use it wisely
This has been how i built the cabinet of defense
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
