How to Measure High Current
About: I'll be doing lots of interesting things here, but mainly :electronics (arduino, analog and digital), computers (old and new), programing (C# and python), linux (administration and hacking). Geeky enterteinm...
I recently bought a pocket multimeter which measures current up to 200 mA, and this was not enough for me. This is way in this instructable i will show you how to make little hack that makes your multimeter able to measure high current.
Supplies:
MultiMeter
1 ohm 10W resisitors
Teacher Notes
Step 1: Build It
All you need is single one ohm resistor, you need to connect voltmeter in parallel to it and now every volt measured by volt meter is one amp flowing through a resistor. You may ask why it is working, i will tell you. Ohms law, our current equals 0,05 amps so the voltage drop across resisitor equals 0,05 volts. This is the easiest way to measure current when your meter does not have range for that.
In addition to that you can connect osciloscope to you resistor and measure current waveform.
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
    audreyobscura
    5 weeks ago
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    In order to be published live on the site and be eligible to enter a contest, an Instructable must consist of the following things:
    - Multiple written steps showing how you made your project
    - Photos in each step
    - Only your own original images
    Check out our free online class that walks you through how to write an Instructable: https://www.instructables.com/class/How-to-Write-an-Instructable-Class/
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email to service@instructables.com.
    Best,
    Instructables Community Manager
