How to Multitask on IPad
This is a tutorial of how to open 2 apps at once, which is called multitasking.
Supplies:
You will need an iPad that is updated to iOS 9 or higher
Teacher Notes
Step 1: Opening the App
You simply open the app. You probably already know that but just in case :>
Step 2: Getting the Dock
Simply swipe up from the bottom of your iPad(iOS 12 & higher, don’t pull it all the way!)You will know the dock is there if you see a list of apps on the bottom.
Step 3: Multitasking
Here’s the final moment; we’re about to do the thing we meant to do! First, tap and hold an app, then, you drag the app to the side until it looks like as what it looks on the second picture. If you want it on the side,(like in the third picture)put it a bit more to the side.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    Josie_Duck2
    Tip 6 weeks ago
    You also have to make sure your device isn’t too old that it can’t do multitasking!!
