First, you need to heat the tablet to open glass background. Be sure to heat 10 minute and be careful to only heat edges, otherwise components of tablet can be broken. Make sure you have your safety glasses and gloves on.
Teacher Notes
Step 1: Step 2: Open the Case
Now, go with a straight knife that doesn't have so much cutting capability. Move the knife slowly. If you rush like I do, you can break the case while opening.
Step 2: Step 3 Detach Battery
There will be a socket which will be connected from battery to mainframe. Detach it carefully, and put away the battery. Remember, the battery used on this tablet, can explode if not handled carefully.
Step 3: Step 4, Enjoy Your Components
That's all for this tutorial! Now you can reuse components for other projects.
Question 6 weeks ago
what will you use these components for?
