How to Propagate a Rubber Plant by Air Layering
Introduction: How to Propagate a Rubber Plant by Air Layering
About: gardening, gardens, crafting & creating. let's make the world a more beautiful place. eco-centric company inspired by nature & lovin' the great outdoors.
We all want our houseplants to grow, right? But what happens when they get too tall, too wide or too leggy? For many plants propagating by cuttings in water or mix works just fine. My Ficus elastica variegata was soon to hit the ceiling so I want to share with you how to propagate a Rubber Plant by air layering.
This method works on other houseplants besides the Rubber Plant. For many of them (including some landscape plants too), air layering is the best method. In a nutshell, you propagate the plant while it’s still attached to the mother. The tough outer layer of the stem or branch is wounded so roots can easily form and emerge.
Some of the other houseplants which air layer beautifully are Weeping Fig, Fiddleleaf Fig, Dracaenas, Dumbcane, Umbrella Tree, Dwarf Umbrella Tree and the Split Leaf Philodendron. The 2 plants which I’ve successfully air layered in the past are the Dumb Cane (Dieffenbachia Tropic Snow) and Burgundy Rubber Plant (Ficus elastica Burgundy).
Teacher Notes
Step 1: Best Time to Air Layer Houseplants:
I’ve always started the air layering process in spring. That way the cutting off & planting (stay tuned – that’s coming in the next post & video) is done in summer.
How long does it take?
The 1st roots generally appear in 2-3 weeks. In 2-3 months time, the air layered portion will be ready to be cut off. This time, I let mine go for 4 months (summer has been hectic!). The air layering & plant are doing just fine.
Materials used:
Floral knife. I bought mine at the San Francisco Flower Market & have had it for over 30 years. It’s light & easy to use. The ever-popular Swiss Army knife works well for this too. Whatever you choose to use, it’s important to make sure your tool is clean & sharp to avoid infection.
Forest moss. This is the natural kind; not dyed. You can also use peat moss or coco coir as well as a combo of 1 of these with the moss. You want a light medium that the roots can easily grow into. For me, the moss is easy to wet, form into a ball & wrap around the wound.
Plastic bag. I used a small, clear produce bag to wrap around the moss. When the intense Tucson summer heat set in, I doubled bag the moss ball so I didn’t have to wet it every few days.
Twine or twist ties. You’ll need something to keep the bag(s) tightly closed on top & bottom.
Rooting hormone. I didn’t use this on my previous air layerings, but because I had been sent a free sample, I used it this time. What rooting hormone does is facilitate rooting, ensures a greater success rate & makes the roots stronger.
A rag. You won’t need this for most houseplants but the Rubber Plant drips out milky sap when the leaves are removed.
Step 2: 8 Simple Steps to Air Layering a Houseplant:
1.) Soak the moss in a bowl of water for 1/2 hour.
Moss is dry & you want to make sure it’s good & wet.
2.) Decide where you’re going to make the cuts.
I went down about 20″ on the stem. That leaves a good amount of base for the plant to regrow on. I plan on stripping off all the lower leaves to turn the mother in a standard (tree) form. For you, the cut points will vary depending on your plant & what you’re trying to achieve.
3.) Remove 2-4 leaves in the area where you’re going to make the cuts.
You’re doing this to make room for the cut & also the moss ball. This is where the rag comes in. Sap will immediately ooze out of the node as well as the leaves stem. Be careful in regards to the sap – more on that further down in “good to know”.
4.) Make the top cut 1/4″ below the top node & the 2nd cut just above the bottom node.
I call this the “band method”. Make the 2nd cut approximately 1/2″ to 1″ below the top cut. It’s necessary to make the cuts deep enough to remove the outer layer but not so deep that you injure the plant.
5.) Make vertical cuts in between the 2 bands & start to pull the outer layer off.
The roots will appear in the cutaway area as well as just above & below the horizontal cuts. The cut area was very wet so I let it air dry for 30 minutes before the next step. I’m not really sure if this matters or not but the wound seemed particularly moist to me.
6.) Apply the rooting hormone.
Mine was a powder formula so I used a cotton swab to dab it on. 7.) Form the wet moss into a ball & wrap it around the cut area. Make sure the moss covers the whole wound. This is what the roots grow into. 8.) Wrap the plastic around the moss ball & tightly secure it top & bottom with the ties. Your plant is now on its way to air layering!
Step 3: Good to Know:
Make sure your plant healthy (leggy or too fall is fine) before you start this process. My plant was well-watered a couple days before I began the propagating.
Apply the right amount of pressure.
Apply pressure, but not too much, when you’re making the cuts. You want to cut deep enough so the new roots can easily emerge. Get the tough layer off but not dig in so deep that it prevents the plant from carrying the nutrients & water to the top. I basically took 1/8 to 1/4″ of the hard top layer off my Rubber Plant stem.
There are 2 other ways to make the cuts, that I know of. The 1st is to make 2 – v notch cuts on opposite sides. 2nd is to make a 3-4″ slit up 1 side. I like the band method because there’s more surface for the roots to emerge (in my opinion anyway!).
Watch out for the sap!
Be careful of the sap that emits from a Rubber Plant as it could irritate you. I’ve gotten it on my skin & it never has bothered me. Never get it on your face & especially not near your eyes or mouth. Also, it can stain your floor, clothes, etc immediately. That’s why I kept a rag handy.
When figuring out where to make the cuts, keep in mind that some plants grow fast. I made my cut almost 2′ down because Rubber Trees grow fast & I don’t want to have to do this again for at least 3 years.
Keep the moss moist.
Don’t let the moss dry out. Those newly formed roots need to be kept moist.
You can also us the air layering technique for these houseplants.
They include the Weeping Fig, Fiddleleaf Fig, Dracaenas, Dumb Cane, Umbrella Tree, Dwarf Umbrella Tree, and the Split Leaf Philodendron.
The air layering process can be a bit intimidating the 1st time you try it but it’s really not hard at all. It’s a tried and true method of propagation, especially for those houseplants which grow tall and or wide and get out of hand. Plus, I’ll get two plants from one!
Happy Gardening,
Nell Foster
JoyUsgarden.com
Be the First to Share
    • Toys and Games Challenge
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
