How to Put a CPU Together.
If you want to put a new CPU on to your motherboard or clean the current CPU you will need
brushes to clean the CPU
Cleaning alcohol
Screwdrivers for the removing the fan screws
Teacher Notes
Step 1: Removing the Fan
Start by removing the wire then the screws after that you can take the fan out
If your fan doest need removing then great we can continue to the next step.
Step 2: Relase the CPU Mount
Remove the silver hook from the CPU mount if done right it should pop open then you can start to clean it or remove the CPU. If so Gently lift up the processor, holding by the edges only
Step 3: Now Repeat Everything Back to Front
Now if you want to put everything back the way it was just follow the steps back to front.
Step 4: Thank You
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    4 Discussions
    Paul Murphy
    Tip 7 months ago
    YOUR Title should be how to insert or mount a CPU surely, forgive me if I miss read what you was trying to do.
    Penolopy BulnickOrion one
    Reply 7 months ago
    You can edit and add to your Instructable at anytime and any additional information you have would be appreciated :D
