How to Read Rfid Rc522 Card With Arduino
Hello friends, I am Anto... in this tutorial, we are going to Learn how to use RC522 RFID module with arduino IDE.
Supplies:
I strongly suggest you to buy the hardwares from UTSource. since their products are good quality and more affordable. Enjoy buying from them with cheapest prize.
1)Arduino Uno 1 x 1
2) RC552 RFID 1 x 1
3)jumper wires
Teacher Notes
Step 1: Gather the Required Components
You can use Arduino UNO, Nano, MEGA for using RC522 RFID. The only difference the pin connection since RC522 RFID works on SPI protocol. you can find the pin connection details on the sample code on the examples...
You can find both Key chain model RFID and tag model transmitter module with unique ID.
Step 2: Download and Add the Library of the RFID
You can download the library from the link below
https://github.com/miguelbalboa/rfid
download the zip file and add to the library as shown the picture. i also attached the library here. if you need my attachment, you can download it and rename to "rfid-master" and add it to the library
Step 3: Construct the Circuit As Per the Circuit Diagram
You can found the actual pins you must connect the RFID module to the arduino on the sample program itself. but i have given as the pics from the sample code. you can connect it such a way
Step 4: Open the Code From the Examples and Download to the Arduino Uno
open the examples from the arduino IDE and click dump info code. I have mentioned it with arrow, so that it can easy for you. click the code and download the code without any editing to the arduino uno. you can able to see the pin details on the example code.
Step 5: Open Serial Monitor on the Arduino IDE
You can open serial monitor on the arduino IDE with 9600 baudrate. now you can observe the text will print on the display.
Step 6: Result
Place the RFID transmitter keychain near the receiver. I just placed at the top of the receiver. that is not necessary. you just keep near is enough. now you will receive an unique id of the RFID tag. i have mentioned it with box at the picture.
For queries... comment below...
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
