How to Repair Led Bulb
Introduction: How to Repair Led Bulb
About: I make diy and electronics based projects.
In this instructables I will show you how to repair led bulb
Teacher Notes
Step 1: Remove the Top Cover
Remove the top cover (diffuser) then desolder two wires of ac mains from the board.
Step 2: More Details in Video
Step 3: Check All Led
Set your multimeter to continuity mode then place your positive lead to positive side of the led and negative lead to negative side of the led. Mark the faulty and led.
Step 4: Remove the Led
Desolder the led carefully.
Step 5: Take a New Led
Step 6: Solder New Led
Step 7: Replace the Capacitor
In the backside you can see two capacitors one is electrolytic and another one is polyester capacitor. Replace that 47mfd/63v electrolytic capacitor with new one.
Step 8:
Creative Misuse Contest
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    5 Discussions
    justme632000
    justme632000
    Question 1 year ago
    Hi, You have not shown the reconnection of the AC power leads to the board, just saying.
    iceng
    iceng
    Answer 1 year ago
    +1
    or why replacing the EL cap was necesssary !
    Electro maker
    Electro maker
    Reply 1 year ago
    Because I repaired 20+ led bulb. In all that bulb the electrolytic capacitors was not functioning thanks.
    iceng
    iceng
    Reply 1 year ago
    Good to know !
    Electro maker
    Electro maker
    Answer 1 year ago
    Oh I forgot it thanks for your valuable comment
