How to Repair an Uneven Concrete Sidewalk
Introduction: How to Repair an Uneven Concrete Sidewalk
About: We're Mother Daughter Projects, sharing our DIY adventures as we learn to maintain, improve, decorate, and use tech in our homes.
With the right tools, repairing an uneven concrete sidewalk is a doable homeowner project.
Supplies:
Makita Diamond Cup Wheel
Makita 7" angle grinder
Makita 12-gal. Xtract Wet/Dry Vacuum
Makita dust collection attachment
Milwaukee Angle Grinder
Diablo 5" Diamond Wheel for Metal Cutting
Safety Gear
Teacher Notes
Step 1: Watch the Video
Step 2: Gather Tools and Protective Gear
This is the uneven sidewalk that needed repair.
It's important to be safe in doing this repair as a lot of fine concrete dust will be released into the air. Use a mask and eye protection as well as dust collection if available or at least work so the dust blows away from you.
Step 3: Cut and Grind Away the Raised Edge
Our first step was to cut away some of the raised portions of the sidewalk with an angle grinder fitted with a Diablo 5" Diamond Wheel for Metal Cutting.
Next, we used a Makita Diamond Cup Wheel on a 7" angle grinder which we connected to a wet/dry vac. We continued to grind the area until we were sure it was no longer a tripping hazard.
Fix It Contest
This is an entry in the
Fix It Contest
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Fix It Contest
      Fix It Contest
