How to Replace a Cpu of a Dell 1510
Introduction: How to Replace a Cpu of a Dell 1510
For supplies you are going to need an esd strap to protect yourself and also a good screwdriver that wont fail you
Teacher Notes
Step 1: Step 1: Take Out Battery
Taking out the battery protects you because if it has any charge the battery will have it and taking it out will prevent you from getting shocked or hurt
Step 2: Step 2: Getting Rid Out Outer Screws
In this step we remove the outer screws so we can open up the back of the pc and also all the back parts of the pc
Step 3: Step 3: We Remove the Backplate and Start Getting to the Motherboard by Removing the Keyboard
you can remove the top part of the computer by inserting the screwdriver into the little divet leading into the powerbutton and volume area
Step 4: Step 4: Once You Get That Off You Can Shimmy the Keyboard by Slowly Shaking and Sliding It Backwards to Get It Out
Step 5: Step 5 Unhooking Monitor
Unplug the monitor cord leading to the motherboard by gently pulling the felt covered cord, then remove the black and white gold cords by gently pulling them out, and also unscrewing the corner screw of the monitor
Step 6: Step 6: Unscrewing the Monitor Completely
Unscrew the screws connecting the monitor to the laptop, and also the small screw next to where the monitor gets its power
Step 7: Step: 7 Take the Monitor and Top of Keyboard Off
Step 8: Step 8: Taking the Cooler Off the CPU
Unscrew the cooler to the pc by unscrewing each side a little at a time this may take a while
Step 9: Step 9: Disengaging the Lock
Disengage the lock by taking a flathead and turning it gently so that it is facing the opposite direction than it started.
Step 10: Step 10: Undo What You Did
I put a list of images that I did following putting it back together
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
