Introduction: How to Restore an Antique Furniture
I wanted to share about my passion. Restoring old and antique furniture. Lately i restored an old cabinet and here are the various steps i followed to give this old fellow a facelift !
Step 1: First Step - Quick Analyse of the Piece of Furniture
At the first glance we can see that the piece of furniture is very dirty, on the inside and on the outside. The bottom of the cabinet has to be replaced. Metal pannels are rusty and will need to be worked on. Also the ledge has disapeared.
Step 2: Disassembly
We are going to disassemble the piece of furniture to work on all the defectuous parts. To do that we will carefully remove the dowels. We already see that the bottom has to be redone and not only because of the rat poops ! We will have to recreate the missing baseboards. We also will have to create a leg on the mortice.
Step 3: The Pannels
The various pannels have also been disassembled et some of the shards will be glued back. The ancient wood has a tendancy to rectract. To give its original dimensions back we will use really thin rods of the same color to complete the pannels. This has to be done on each pannel.
Step 4: Pegs and Mortises
Removing the frame is easy thanks to the pegs that are easy to remove. On the side we will need to pierce in order to extract the pegs. The leg being in such a bad shape, we will crate new ones in the same wood.
Step 5: The Drawers
Drawers are in a bad shape. Slides have to be changed. We make the lath using balls of chestnut.
Step 6: Rebuilding the Cabinet
The side pannels have been rebuilt with new pegs.To keep authenticity we decided to use parts of an old cabinet but the side pannels are brand new. For the bottom part we used the same technique meaning we used woods of an old cabinet. The wood buttons have been replace by an old lock using the same material as the bottom of the cabinet.
Step 7: Completion
The cabinet is finaly cleaned and brightened. The sawing at the back is kept to keep authenticity. On the side we removed oxydation from the metalic pannels. So here we are, you just witnessed the various step i follow to restore an antique cabinet !
Find more on my old website here: http://lartisandumeuble.free.fr
And if you liked it support my new professionnal website : http://lebonpeintre.pro
