How to Rewind BLDC
  • Rewinding BLDC motor
Step 1: Introduction
BLDC (Brush Less Direct Current ) Motor most offen used in drones .but unfortunately it will burn during heavy work load .so i will instruct how to recover it inorder to save few bucks
Step 2: Remove the Pin
Step 3: Removing Coil
  • remove the out runner
  • use screw driver as lever mechanism to remove the coil
Step 4: Winding Coil
  • Follow the images
  • wind as tight as possible
  • clear instruction given on video
Step 5: Decide the Connection
  • Go for delta connection u will get more speed
Step 6: Putting Back the Coil
  • apply some epoxy to fix the coil tightly
Step 7: Test the Motor
  • connect to ESC
  • run a test drive
    • Paint Challenge
      Paint Challenge
    • DIY Summer Camp Contest
    • Classroom Science Contest
    АхмедА
    4 weeks ago
    Thanks for the explanation
