How to Solve a Math Problem Using PEMDAS
Write out your equation. Leave enough space to write each step of your work.
What you'll need:
  • Equation
  • Pen/Pencil
  • Paper
Teacher Notes
Step 1: Identify Parenthesis
The first step in PEMDAS is P=parenthesis.
Identify and underline all sets of parenthesis. If there are none, proceed to "Identify Exponents."
Step 2: Solve Underlined Parenthesis
Solve the underlined parenthesis. Work from left to right.
Step 3: Rewrite Equation
Replace the parenthesis with the corresponding value.
Step 4: Identify Exponents
The next step in PEMDAS is E=exponents.
Identify and underline all exponents. If there are none proceed to "Identify Multiplication Problems."
Step 5: Solve Exponents
Solve the first set of exponents. Work from left to right.
Step 6: Solve Exponents
Solve the next set of exponents. Work from left to right.
Step 7: Rewrite Equation
Replace the exponents with the corresponding value.
Step 8: Identify Multiplication Problems
The next step in PEMDAS is M=multiplication.
Identify and underline multiplication problems, working from left to right. If there are none, proceed to "Identify Division Problems."
Step 9: Solve Multiplication Problems
Solve the first underlined multiplication problems. Work from left to right.
Step 10: Rewrite Equation
Replace the multiplication problem with the correct value.
Step 11: Identify Division Problems
The next step of PEMDAS is D=division.
Identify and underline all division problems, working from left to right. If there are none, proceed to "Identify Addition Problems."
Step 12: Identify Addition Problems
The next step of PEMDAS is A=addition.
Identify and underline all addition problems, working from left to right. If there are none proceed to "Identify Subtraction Problems."
Step 13: Solve Addition Problems
Solve the underlined addition problems. Work from left to right.
Step 14: Rewrite Equation
Replace the addition problems with the corresponding value.
Step 15: Identify Subtraction Problems
The final step of PEMDAS is S=subtraction.
Identify the subtraction problems. For this equation, this is the only problem left to solve.
Step 16: Find Your Answer
Congratulations, you have used PEMDAS to solve this math equation!
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    3 Discussions
    tlaci2007
    6 days ago
    It's false. Addition and subtraction are equal according to order of operations, so operations must be performed from left to right. So the result is: 81-36+9 = 45+9 = 54
    bakichmg
    6 days ago
    Thanks for this. I was just arguing with someone about the rules. Showed this to assist with correct procedure.
    audreyobscura
    7 days ago
    Cool tips! Thanks for the share!
