Introduction: How to Transfer Music Between Phone and Computer?
If you are a Samsung mobile phone, you must fed up with the sluggish speed and fussy operations in transferring music and songs between Samsung mobile phone and computer with Samsung Kies software, right? Then, is there any other third-party tool to help transfer music from mobile phone to computer and copy songs from computer to phone? Certainly the answer is YES! In this article, we will show you an easy-to-use yet powerful Kies alternative tool.
iPubsoft Phone to Computer Transferis what I want to recommend that can not only transfer music between Samsung and other Android mobile phone and computer, but also copy videos, photos, books, apps and more files between phone and computer with ease. With it, you can even backup text messages and contacts on computer, and then edit and manage them on computer directly. Texting from computer to any phone number is also enabled.
Step 1: Run the Software and Connect Your Phone
Download, install and run the Phone to Computer Transfer. Connect your phone to the same computer via a USB cord. You may need to follow the steps as below to enable USB debugging on your phone firstly:
1) For Android 2.3 or earlier: Enter "Settings" < Click "Applications" < Click "Development" < Check "USB debugging". 2) For Android 3.0 to 4.1: Enter "Settings" < Click "Developer options" < Check "USB debugging". 3) For Android 4.2 or newer: Enter "Settings" < Click "About Phone" < Tap "Build number" for several times until getting a note "You are under developer mode" < Back to "Settings" < Click "Developer options" < Check "USB debugging".
Step 2: Preview and Select the Music for Transfer
Once the USB debugging is enabled, your phone will be detected and all the files in your phone displayed in the top menu in the program interface. Choose the "Music" tab and bring out all the songs contained in your phone.
Step 3: Copy Songs Between Phone and Pc
Choose the music you want to copy to computer and click the "Export" button, select the output location on your computer where you want to save these music files. Or you can click the "Import" button to copy music from computer to your phone.
If you still have any question, you can visit here:
